Driverside Power Lock Problem??
Old Apr 2, 2007 | 11:04 AM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Question Driverside Power Lock Problem??
Anyone else have issues like this? My driver side door won't unlock w/ the key fob. Well sometimes it will, but not that often. This just started happening out of the blue. I'm taking it in this week to be checked. Possible causes.... Bad Motor, Bad Key Fob, etc?
Old Apr 2, 2007 | 11:33 AM
sliderg35's Avatar
If it's just the driver's side, your FOB is fine. The dealer will have to fix the switch or motor.
Old Apr 2, 2007 | 11:43 AM
G35kidd's Avatar
its the passenger door for me
Old Apr 2, 2007 | 11:56 AM
gqong's Avatar
sounds like a bad lock...the actuator is gone..
Old Apr 2, 2007 | 12:59 PM
gspotter's Avatar
Check the keyfob battery.
Old Apr 2, 2007 | 01:18 PM
PapiDG_G's Avatar
This started happening on my passengers door
Old Apr 2, 2007 | 02:41 PM
Jebsleo's Avatar
Correct. Hopefully the OP has warranty. Had the same problem.
Old Apr 2, 2007 | 02:56 PM
nghiars's Avatar
my car was just in the dealer last week for this.. they didnt know if it was the actuator, motor or line so they replaced the whole thing. under warranty
Old Apr 2, 2007 | 11:04 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Hopefully it something simple.... I just got off and made it home and realized I didn't have any problem with the door when I left the job. Its going to work perfectly fine when I take it in, I just know it!!
Old Apr 3, 2007 | 09:21 AM
kryptkicker's Avatar
Any idea on how much it costs to have this fixed? My wife's coupe won't lock/unlock with the fob. You have to insert the key and lock/unlock the door...
Old Apr 5, 2007 | 03:04 PM
G35kidd's Avatar
It's probably the battery in the key fob
Old Apr 5, 2007 | 03:11 PM
LjN_728's Avatar
Why don't you try the spare key fob and see if the problem persist.
Old Apr 6, 2007 | 10:24 AM
b/c the passenger side still locks/unlocks with the key fob... I know it's not the fob that's bad.
Old Apr 6, 2007 | 01:14 PM
1slowblackG35's Avatar
Ditto for me, only the drives side will work 20% of the time, mostly have to use the key!
Old Apr 6, 2007 | 01:18 PM
gqong's Avatar
its the lock actuator i was out of warranty and had to fix it myself.
