Steering wheel airbag replacement: compatiablity issues
Old Apr 3, 2007 | 10:27 PM
6mt2005's Avatar
I need to replace a blown steering wheel airbag on my 2006 G35 coupe. Would the steering wheel airbags from older 2003-2005 G35 coupe work on a 2006? Also would an airbag from a 2003-2005 G35 sedan work?
thanks
Old Apr 3, 2007 | 11:14 PM
Paperchaser's Avatar
I am 100% sure that driver airbag is the same from 05-06 coupe or sedan
Im pretty sure the 03-04 bag works also (only driver side) but color wont match exactly but I cant say Im 100% sure on that
also it is very easy to change urself I posted a DIY last year
https://g35driver.com/forums/interior/124147-diy-driver-airbag-replacement-w-pics.html
Old Apr 3, 2007 | 11:19 PM
ttrank's Avatar
Grocery getter
I am not 100% sure on the 03/04 wheel but I believe it will also fit.
Old Apr 3, 2007 | 11:25 PM
Ive fixed 4 salvage G35's over the past few yrs, 3 coupes & 1 sedan so ive mixed & matched parts on occassion depending on what was available at the time. but its been a while so im not 100% sure on the 03-04 bag
Old Apr 4, 2007 | 01:31 PM
6mt2005's Avatar
Are you not sure on the 03-04 sedan bag or both sedan and coupe airbags.
Old Apr 5, 2007 | 06:03 PM
as far as sedan or coupe the driver wheel airbag is the same
I am about 95% sure that the 03-04 driver airbag will work on an 05-06
I did have a 05 airbag in an 04 coupe but this was before SRS module was changed so airbag light was still on so. this is why I wont say im 100% sure, just cuz it plugged in & fit doesnt mean it would have worked I later swapped out 05 bag for an 03 bag because it was the the correct color, therefore i never found out for sure. from my experience i think it would work no problem
Old Apr 5, 2007 | 06:12 PM
6mt2005's Avatar
Thanks. I guess I'll get a 05-06 airbag just to avoid problems.
Luisgalvan33
Jul 19, 2018 08:16 PM
kd03g99
Jul 30, 2015 11:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
Karnicle
Jul 23, 2015 05:08 AM
