damn!!! look what I did during changing cabin air filter!
Old Apr 23, 2007 | 06:52 PM
ksj4340's Avatar
during installing grounding wire, I changed my cabin air filter also.
But while I was installing ECU wire, I heard sound that something took off!
But wtf! it was a plastic cover that goes into the way inside of cabin air box.
I am attatching a pic of it.
then I tried to put this back on for about an hour, but I couldn't.
It was so small space for me to put it back on.
So, here's the question, do I really have to have it? or is this just for preventing some rocks or leaves go in?
Please help guys.
Attached Thumbnails damn!!! look what I did during changing cabin air filter!-airfilter.jpg
Old Apr 23, 2007 | 06:56 PM
filanj's Avatar
hmm that is weird
Old Apr 23, 2007 | 07:10 PM
ksj4340's Avatar
Originally Posted by filanj
hmm that is weird
Do I really have to have it back on?
Old Apr 23, 2007 | 07:14 PM
GEE35FX's Avatar
Hopefully someone with a service manual or experience with it can chime in.
It definitely looks like a door that is hinged and has a sealing surface on that one side. Looks like it is to stop flow in one direction. Looks like a necessary part to me .
Old Apr 23, 2007 | 07:22 PM
JOKER's Avatar
CLUB MODERATOR
toss it. Reduce the weight of the car.
Find more pieces of "Fantastic Plastic" and toss them too.
Old Apr 23, 2007 | 07:53 PM
Konazo's Avatar
You should turn on you climate controls and switch from recycled air to fresh air, from dash vents to floor vents, or turn on your AC and make sure your not getting hot air from outside. It looks like some type of Blend air door.
Old Apr 23, 2007 | 11:02 PM
BadBoy06's Avatar
hmmm, find the tech manual for that area. looks like
some type of functional piece..may have to bend it to get it back in
from the looks of it.
Old Apr 23, 2007 | 11:17 PM
GLuXuRy's Avatar
isnt that a vent control door for the AC ?
Old Apr 24, 2007 | 12:59 AM
htownboy's Avatar
Please help guys.
You must have that; sorry, it's called a blend-air door by many ASE techs and it is needed for proper operation of the AC fresh to recirculated air.
Old Apr 24, 2007 | 07:20 AM
runningonmt's Avatar
It looks like part no. 14 in the enclosed diagram. Good luck putting it back on.
Attached Thumbnails damn!!! look what I did during changing cabin air filter!-blower_housing.jpg
Old Apr 24, 2007 | 11:22 AM
LjN_728's Avatar
At least you're getting to know more about your car? jk Shouldn't be difficult. Just a matter of getting the left tab in first then pushing into place.
Old May 2, 2007 | 04:04 PM
PEARL-G's Avatar
Hey, Go Inside Your Car And Check Your Air FLOW. Check Your Dual Climate Control. Make Sure That You Are Getting An Even Seperation Of Air. Hot Air On Left/ Right Or Cold Air Left/right. And Check Your Recirculate Button.
Old May 2, 2007 | 09:22 PM
GTT's Avatar
GTT
G35 Twin Turbo
Please help guys.
just take it to the dealer they should take care of it
Old May 3, 2007 | 06:41 AM
g35rcr's Avatar
as they charge you...you did the damage why would they fix it for free
Old May 3, 2007 | 10:34 AM
kidtronix's Avatar
Optional
Yeah its a baffle that is probably for redirecting the airflow according to what MODE you've chosen for your HVAC. You need it in there...but I haven't the slightest idea how the hell to get it back where it belongs...or if you've broken it. It looks to be ok to me...but is the right side of the hinge intact? Or does it set onto a post instead of clicking into a hinge like the left side?
