Gas door stuck
I just went out and looked at mine. There is no "cable" controlling the lock. My first thought was that maybe you hit the trunk lock in the glove box, so I tried that and it didn't lock the gas while engaged. The lock is a little plastic piece that has an angle on the point cut away from the car. If you are able to CAREFULLY get something in there that would be able to un-engage the piece it should retract. The piece is directly on the axis of the lid on the left side (obviously).
It may have just gunked up just enough to not be able to retract. If it were me and I were not able to take it to a dealer I would try spraying a small amount of WD-40 in there, then silicone spray, then Simple Green VERY carefully and not much of a squirt of it either (hoping that the gas cap was locked tight!)
This happened to me too. I had to force it open and wound up breaking the flimsy plastic pivot that keeps it locked. I would advise everyone to lubicate the little plastic thing that retracts from the hole inside the hinge. The G's gas door is not water tight so things tend to get dirty and wet in there.
I am not sure, but i have this problem too.. i figure out taht you need to unlock your door to open the gas door. If your doors are lock, you can't open the gas door.. Hope this help.
Sooiseng
Sooiseng
my spring release stuck once. It actually broke and jammed up. I had to used my Driver License and pop the door open. Can you tell if hte lock is stuck in the locked possition? If its not, just try to get your finger nail ir something thru the gas door jam area and pop it open. There wasnt much resistance on mine.
Originally Posted by Kidcane
Same here, mine was stuck so I just pryed it open because I was out of gas. Then I took it to the dealership and it was covered under warentee.
Did you scratch the paint?
