Vibration? rattle Coupe? Passanger side 06
Old May 2, 2007 | 04:42 AM
justice76's Avatar
I get this strange vibaration rattle coming from the passanger side seems to be far air vent or speaker but I can not pin it down
Seems if I get a person in the car it does not come out, you know how that goes.
Anyone run into this?
Thanks so much
Old May 2, 2007 | 01:43 PM
mikeb12's Avatar
the little frame between the dvd box and the glove box?
Old May 2, 2007 | 05:17 PM
SkyBlueG35's Avatar
factory installed rattling devices one of the joys of owning a G
Old May 2, 2007 | 05:25 PM
MeetJoeAsian's Avatar
i heard a rattling too, then I checked...it was the passenger seat belt thinggy that was tapping against the side wall pillar...
Old May 2, 2007 | 05:29 PM
BadBoy06's Avatar
yep..thats been my only rattle driving on nice roads help
Old May 2, 2007 | 05:31 PM
turbo83lude's Avatar
also had a rattle coming from the passenger side, which ended up being the passenger speaker cover. when i took the car in for a oil change, i had them fix it, which they did then it came back after a while. then took it once again at the next oil change, and so far so good.
but now theres a rattle coming from the back somewhere.
Old May 2, 2007 | 07:51 PM
Algy's Avatar
i know what your talking about! but it doesnt seem to bother me cause i barely get it cause there are nice roads here!
Old May 2, 2007 | 07:58 PM
jonnylaw's Avatar
rattles are common on these cars--just turn up the volume on the stereo. Having the dealership try to identify the rattle and attempt to fix it w/ silicon and such might actually lead to more rattels and problems imo--I would only really seek repair if the rattle is horrible.
Old May 2, 2007 | 09:00 PM
BadBoy06's Avatar
maybe instead of stereo..use the gas pedal for music
Old May 3, 2007 | 02:27 AM
JackD's Avatar
try touching the speaker cover and see if it goes away. I had the rattle comming from the speaker cover if I touched and held it it stoped, the second I let go it came back. It drove me nuts, took the dealer 3 tries before admitting there was something there. My eight ear old could hear it bu not the mechanic even after telling him what was making the noise. They replaced the whole door panel and so far its good.
Old May 3, 2007 | 12:50 PM
Hitman_'s Avatar
if the speaker cover is the source, easy fix fellas. Just use clear silicone and fill in a bit in four corners of the cover, will stop it from making any further noise.
Old May 3, 2007 | 02:29 PM
watsgoodG's Avatar
mine rattles also and it seems to get worse and worse...when i hit the cluch i dont hear it when its not depressed and parked its pretty loud...
Old May 22, 2007 | 12:08 PM
Dorsett's Avatar
This same rattel has been bothering for awhile now and I was to the point of changing the speaker but if it is the speaker cover will that make any differance and is there a DIY detailed article to fixing the speaker cover
Thanks
Old May 22, 2007 | 12:34 PM
alphamatt's Avatar
agreed, i have to ride with my knee pressed against my door, now if only i had an unproportional right leg i could reach the other side....but i dont, so she do the rattlesnake
Old May 22, 2007 | 07:11 PM
j0N731's Avatar
I had this same issue, for me I found out that it was my sunglasses lol, I swore i was from the passenger speakers so I asked my friend to sit in it with me while i drove. He touched the sunglass holder and the rattle stopped
