Serious problem over ~4000RPM in 6M/T
Old 01-03-2004, 03:00 AM
mvorion's Avatar
Re: Serious problem over ~4000RPM in 6M/T
I forgot to mention the car will also stall if shifting into neutral after hard acceleration, and not necessarily holding down the clutch. The RPM's will just drop to 0, so this would rule out old_s13 and Rainmeister's suggestions. I don't have the Stillen air box either.
2004 G35C 6MT DG/G Premium, Alum Pedals, Huper Optik 30/40/50, Z-Tube, K&N Drop in
Old 01-03-2004, 05:18 AM
old_s13's Avatar
well, you have to see what your idle is set at.. if its too low, have it bumped up. i dont think its a serious issue, but regardless.. its something to work on.
good luck!
-m
http://www.ClearCorners.Com -//- There are four corners to this world, we're clearing each one, one step at a time.
Old 01-03-2004, 01:26 PM
nuttyprof's Avatar
the engine idle resets and stuff on the technosquare website may help. i had that problem after my install, but after the resets, it went away.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old 01-27-2004, 05:19 PM
d3g's Avatar
d3g
d3g is offline
Well I have had this same problem for months now and have done the Gas/p, Accelerator Pedal, Throttle Valve, and Idle Air Volume Learning resets (in that order). Although I can tell a diff after a ECU reset and the Air Volume reset, none of these resets help with my idle. It just seems to keep dropping down to around 400 RPM. My coupe is a 5AT. The resets will help the idle, but it ends up back at around 400 RPM. I do know that this didn't start until I installed the Stillen box. At that time I had nothing else installed. I installed the 350Z tube a couple of weeks ago, but it didnt make the problem worse or better. I guess I need to take it to the shop. I have been thinking about installing my stock air box and doing a reset to try to isolate the problem to the Stillen Air Box but gawed what a pain. If anyone has any more ideas or information on this please share.
www.corevoltage.com
Stillen Box | Fallsgate Amp | Projection Fogs
Freeman186
09-06-2023 10:07 AM
bryanr
Drivetrain
09-30-2015 06:31 AM
Ohsixgee35
09-16-2015 04:33 AM
Jnm07
09-05-2015 01:16 AM
kevintandmd
09-03-2015 06:41 PM
Quick Reply: Serious problem over ~4000RPM in 6M/T
