Speedo problem...
Old May 11, 2007 | 10:58 AM
BrokeGDriver's Avatar
Speedo problem...
My speedometer stopped working on my 07 coupe today...I went to check out the speed sensor thinking maybe it got messed up or something, but I can't find where it is located. I thought it might be the one on top of the case that is hard to get to but it didn't work when i finally did get it unplugged...Any suggestions?
Old May 11, 2007 | 11:02 AM
KPierson's Avatar
The VSS signal is derived from the ABS sensors in each wheel.
Old May 11, 2007 | 11:27 AM
jgainnm's Avatar
Isn't this the sort of problem a warranty should address?
Old May 11, 2007 | 11:37 AM
MeetJoeAsian's Avatar
dude...I don't want to see you in a speedo, much less helping you with your problem...
Old May 11, 2007 | 11:38 AM
AthensBlueG's Avatar
Brian
^^Without a doubt, this is covered under warranty!! I personally wouldn't think twice about taking it to the dealer to have it fixed right away.
Old May 11, 2007 | 02:25 PM
mike281's Avatar
Mike Team350GZ
ya y would u try to fix it it's not worth your headache thats wut a warranty is for man.
Old May 11, 2007 | 03:41 PM
ttrank's Avatar
Grocery getter
+1 take it in.
Do you get any other lights on your dash? If you pull the ABS fuse my speedo doesn't work.
Msedanman
Sep 21, 2024 07:56 AM
chinee
Jun 10, 2024 07:48 PM
juggernaut
Sep 20, 2004 01:18 PM
cke73
Jul 11, 2004 06:05 PM
badboyg200
Apr 1, 2003 08:42 PM
