click/pop sound from rear when put in drive
as my sig states i have an 05 5at cpe whenever i start the car depress the brake and put the car into drive i get a click or pop coming from the rear wheels. Also at times while the car is running i can also get the clickor pop to occur if i move from a dead stop at times. Finally I cal also get it when i drop it into reverse from a dead stop when i first start the car with brake engaged. Is this normal
its hot so with the windows down its very noticable, again a single tick/pop, but with windows up i don't notice it/its not audible. Any info/sugestions would be much appreciated thanks all
Originally Posted by killahb36
thx
i'll bring her on down to the dealer is this going to damage something overtime?
i'll bring her on down to the dealer is this going to damage something overtime?Trending Topics
DevilDog you were correct thank you it was the driveshaft tsb took it to the dealer and got my free oil change, no more poppin
Originally Posted by Devil Dog
Cool, glad something I posted actually helped someone.
The notorious axle click. Does every 05 have this problem? Will they fix it if I am lowered or will they try some BS that it is clicking because its lowered?
Has anybody had a problem getting it fixed?
I'm a 2005 with 18k miles and no axle click, knock on (wood/veneer/laminate, whatever!) but I do have an annoying window rattle.
Too bad the nearest Infiniti dealer is 176 miles away.
