popping sound - right rear
Old Jan 6, 2004 | 10:25 PM
rksato's Avatar
Anyone have a popping sound coming out of the right rear during right hand turns - seems to be primarily into right hand driveways where there is lots of right rear wheel travel. Sounds like someone gives the right rear side of the car a good "flick". Can make it happen when I throw the car left before entering a driveway on the right.
Even had the factory people work on it - re-torqued the axle, etc.
Old Jan 7, 2004 | 09:33 AM
KAHBOOM's Avatar
Re: popping sound - right rear
I've noticed the same thing on occassion and plan to get it checked out soon.. the exact same scenerio
<font color=black> Black/Willow Coupe </font color=black>
Premium Package
18" Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Jan 7, 2004 | 09:59 AM
tonke73's Avatar
Check to see if your jack, tire iron, etc is secure. It is located in the right rear. You might save some embarrasment at the dealership.
Old Jan 7, 2004 | 12:18 PM
bjg's Avatar
bjg
your probably scrapping your tailpipe.
Old Jan 7, 2004 | 01:06 PM
mkmbt's Avatar
I had a similar thing going on in my coupe but it occurred when going over rough pavement or bumps. Sounded more like a ticking rattle. The culprit was some flange bolts or nuts that had come loose. I can imagine that if they became real loose, they might make more of a popping sound.
Old Nov 14, 2006 | 05:29 AM
JC-RH's Avatar
wow, sorry to revive such an old thread. what do you mean by "flange bolts or nuts?" i've read about so many people having a popping noise coming from the passenger rear when hitting bumps. no one has come up with a real solution.
Old Nov 14, 2006 | 03:15 PM
cloud's Avatar
I have that issue took it to the dealers and they said they could not replicate the problem.
Old Nov 14, 2006 | 09:46 PM
ARTofDESIGN's Avatar
axle TSB
TWASkyliner
Feb 8, 2020 08:00 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
atk08
Jul 30, 2015 03:12 PM
