Clutch/neutral on down hill?
Old Jan 9, 2004 | 09:23 PM
  #31
Hitman's Avatar
Re: Clutch/neutral on down hill?
Actualy, this fuel cut-off occurs until the engine RPM fall to a set value at which point fuel is restored for idle condition
<hr></blockquote>
Nope. The fuel cut has nothing to do with reaching an idle condition.
Where do you guys get your information?
Is it so hard to believe that the engine can go without fuel during deceleration/coasting?
For all you non-believers-- do some research and learn something before making false statements.
Old Jan 10, 2004 | 09:50 PM
  #32
zensokuryoku's Avatar
ok...i think hitman is pretty on it.
you use very little fuel while at idle (so coasting in neutral is still consuming fuel albeit small amounts)
and under full deceleration (in gear) you are using zero fuel because the injectors are off.
jsimonk
Dec 22, 2023 03:49 PM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
