Brake Light, Slip Light, And Vdc Light Wont Turn Off!!!!!!!
Old Jun 2, 2007 | 04:51 PM
VQPWNAGE03's Avatar
I have a 03 coupe and i was driving on the freeway last night when all of a sudden ALL of the 3 lights turned on. I pulled over and turned off my car for a bit, and when i turned it on again it was fine, until i gave it some gas and the lights reappeared. SOMEONE PLEASE HELP ME!!!!
-Jon
Old Jun 2, 2007 | 05:01 PM
cwhealon78's Avatar
check ur break fluid it could be low
Old Jun 2, 2007 | 06:47 PM
Rphillips6487's Avatar
did you recently lower your car? put in a mod?
either way, you need to have our ecu reflashed, bring it down to infiniti, hopefully you have your warranty
Old Jun 2, 2007 | 07:02 PM
GeeDM's Avatar
from what i've seen its either 1) your brake fluid is low (as above mentioned) or 2) your brakes need to be replaced.
Old Jun 2, 2007 | 07:12 PM
MeSince83's Avatar
this happened to me when I forgot to re-attach a sensor. You should check if your sensors are all attach properly.
Old Jun 2, 2007 | 07:30 PM
Pabloescobar988's Avatar
Check the fuse for the brake light, when its off the VDC and other lights will come on. Could be that
Old Jun 3, 2007 | 03:20 AM
Calvin's Avatar
Overglorified Altima
brake fluids.
Old Jun 3, 2007 | 09:51 AM
frshgcoupe's Avatar
same exact thing happened to me, yupp its your brake fluids
Old Jun 4, 2007 | 01:41 AM
VQPWNAGE03's Avatar
thanks for the help guys. Gonna go get it done tomorrow.
-Jon.
Old Jun 4, 2007 | 01:43 AM
cungkpham's Avatar
spc spacers?
Old Jun 4, 2007 | 02:12 AM
ttrank's Avatar
Grocery getter
I have had this come on for the following reasons:
1) Brake fluid is low because pads are warn.
2) Fuse is blown or removed from ABS or rear brake lights.
3) Tire diameter is not the same between the front and rear and is off by too much. My case was 6%+.
Old Aug 31, 2007 | 01:21 AM
Heikes's Avatar
I know this is an old post, but I just needed to tell you people how much grief you just saved me. I just installed a kinetix V+, Z-Tube, JWT Pop Charger, new brake pads/rotors front and rear, stainless lines, and wheel spacers. The dreaded triangle of idiot lights just came on today and I had no idea where to start with all the new mods. Checked the brake fluid and it was not topped off so that fixed it. Now I just have to find out why I was low and where is it leaking. Thanks again G35Driver!!
Old Aug 31, 2007 | 02:19 AM
redlude97's Avatar
If you had new lines installed, my guess is there, or you simply didnt top off the fluid correctly while bleeding
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
