triptonic question
Old Jun 3, 2007 | 03:57 PM
sahiwal007's Avatar
triptonic question
hey,
alot of people told me that using triptonics is not good for the engine? they were saying that it messes up the transmisson. is it true? and also at what rpm's should i shift with the triptonics?
thanks
Old Jun 3, 2007 | 03:59 PM
empfl's Avatar
I don't think tiptronic has any negative effect on your transmission. As long as you dont switch to often between D and tiptronic
As for revs, well it all depends on your driving style. So for cruising shift around 2-3K. But you punchin that ****.. obviously hit the red.
Old Jun 3, 2007 | 04:25 PM
GreenGoblin's Avatar
The goblin resurrection
i dont think that infiniti you design a feature like that with out some reasearch iam sure that it has no effect on the trans
Old Jun 3, 2007 | 04:46 PM
Calvin's Avatar
Overglorified Altima
doesn't matter how often you switch from d to manumode.
shift whenever you feel comfortable..
Old Jun 3, 2007 | 04:48 PM
w0ady's Avatar
fgc moderator
+1. redline or not, its designed to be foolproof.
Old Jun 3, 2007 | 05:01 PM
Fassster10's Avatar
if its bad for the engine my G for sure its not showing any negative side effects, as i always use it when i like to open her up
Old Jun 3, 2007 | 08:03 PM
BabyGT's Avatar
where did ur friend get these wrong ideas? there's no way infiniti would put it in production if it is bad for the engine or trans.
Old Jun 3, 2007 | 08:29 PM
Jtrain's Avatar
You honestly couldn't be any more wrong.
You can get some stupid bad shifts and really mess up your tranny.
Just using it wont mess it up, but when you downshift and get those clunks or goofy kinda feel to it... then you definitely did damage.. My tranny only lasted 31,000 miles... 29,000 of those probably tiptronic.
While we are on this topic, you think there is a way to put the sedan stearing wheel on our coupe for paddle shifting?
or something like that.
Old Jun 3, 2007 | 08:45 PM
nickvvv's Avatar
I just started using my triptronic, and i love it. I guess aslong as u dont go into the red, ur fine. I noticed that for first and second gear on auto it shifts at around 2500 rpm. So when I wanna give her I let it rev upto about 6,000 rpm. Pulls alot more. I'll even drive around in 2nd gear at about 60km/h with the revs up around 3,000 rpm just cause I like to hear that music note from the exhaust. lol.
Old Jun 3, 2007 | 09:14 PM
PostShawn's Avatar
Different car but when I get a G it will probably be an AT so I am going to look into that mod. Here is a mod they did on a different car with a triptronic type of trans that they were able to install paddles onto. Doesn't look all that hard or cost too much. http://www.lincolnvscadillac.com/sho...t=paddle+shift
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
