HELP !!!!! Trunk removal advice......
Old Jun 13, 2007 | 11:28 PM
WACK BEATS's Avatar
Question HELP !!!!! Trunk removal advice......
To those who have done this HELP!!!! I planning to do a trunk swap. IM going from spoiler to spoiler-less. How did you all remove your trunks. Did you unbolt it from the dampers or did you unbolt it from the car frame and include the damper in the swap. and how did you disconnect the wires. ALso how would the guy getting my trunk/spoiler rewire them back to his car. Any help/advice is greatly appreciated.
Old Jun 13, 2007 | 11:47 PM
WACK BEATS's Avatar
anyone?
Old Jun 14, 2007 | 12:55 AM
cungkpham's Avatar
there are 4 torx screws that are made of aluminum (2 on each side). Be prepared to drill them out bc they are REALLY SOFT and you will probably strip them. before you unscew them, there is a connector under the trunk liner for the 3rd brake lamp, its on the right rear of the rear trunk panel; disconnect. have two or 3 people including urself to hold the trunk and unscrew.
it takes 5 mins max to take it off. it really easy.
Old Jun 14, 2007 | 12:58 AM
WACK BEATS's Avatar
thanks !!!!
Old Jun 14, 2007 | 12:59 AM
cungkpham's Avatar
to unbolt the dampeners, take a flat head and wedge it bwtween the metal clip (once you see it, you'll know what im talking about). keep flat head in there, and pull the dampener out.
Old Jun 14, 2007 | 01:54 AM
WACK BEATS's Avatar
got it thanks!!! i think im just gonna unblot everything from the car. i dont want to take a chance @ stripping the torx screws.
Old Jun 14, 2007 | 03:56 AM
WACK BEATS's Avatar
got it off. easier than i thought. i unbolted the entire thing off the car. no problems..
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Oregon13
Mar 1, 2016 12:06 AM
