i no most of u guys have gone crazy with ur g's and most of them ARENT stock, i was wondering what the fastest time for a g in the 1/4 mile would be for a near stock sedan or coupe. some guy ran 14.2 in an 04 tl. do u guys think that is fast? most of ur cars are probably faster, but can a stock g sedan/coupe better that time?
Coupe times considering good driver, track condition, etc.
14.0 - 14.2 manual
14.3 - 14.5 auto
Sedan times considering good driver, etc
14.1 - 14.2 manual
14.3 - 14.5 auto
Note: all cars stock with 1/4 tank of premium gas. If somebody number is above those I listed he/she needs to learn how to drive and practise on track with different rpm launch, tire psi, etc.
2004 G35s auto (bone stock)
2002 s/c Accord V6 auto
so far best 1/4 mile - 13.9@101.8
coming soon: custom internals, cams, performance auto tranny w/LSD
The new TL should be pretty close to a G35 stock vs stock. Maybe a tenth or two difference, but nothing major. If you had a range for the TL, just like the G35 numbers listed above I'm sure they'd probably overlap quite a bit.
Justin McClanahan
Heavily Modified 95 Infiniti G20
Working on a G35 Project Coupe
http://www.infinitipa.zoovy.com -> www.EverythingG35.com
Justin McClanahan
Guest
If you just want to run 1/4 mile times faster, all you need is slicks or drag radials. 13's are no problem and the car is still stock. Actually if you really just care about the 1/4, you can't be AWD. RWD is far better than FWD since weight transfers onto(instead of away from) the drive wheels. This is also why RWD has a trmendous advantage over FWD on a road course. An EVO VIII is the best way to go. You can run 12's on street tires with only $1000 in parts. G35's are great top runners, just not off the line. 0-130 times are much more aggressive. I don't know if it is the computer or the rear suspension, but they just aren't getting great 60' times. FWD though has a lot more of a limit to this than RWD. When I had the supercharger in my Maxima; as soon as I hit 3500 rpms in first, my 245 tires would break loose. Even partial throttling would break them loose from the torque ramp-up. I could never get traction. As a result, I ran a 14.1 @ 107 with a 2.5 sec 60'. Not a very impressive ET, but the trap speed is a bigger key. Despite the ET, I would walk any high 13 second RWD car. I even beat a Grand National that runs 12.5(traction bars and drag radials) 1/4's on a 60 punch. 1/4 mile is not everthing.
04' G35 Coupe(finally in the garage)
6-sp Diamond Graphite/Willow w/Premium
I know the 1/4 mile track my self and a few others went to last wednesday is a really slow track with a 4000 foot elevation..
my time with horrible launches was 14.375... with altitude time adjustments it was a 13.4
going to track tommorow..
irwindale cali if anyone wants to come... we will be getting there early...
Jason
AIM: PerformanceNISMO
Yahoo: MyNISMOParts
http://www.performancenissanparts.com
Jason
Yahoo: MyNISMOParts
I ran a best of 14.08@101.7mph(2.14 60') with just an ecu reset, 25 psi in the rear tires/40psi front, no spare, no passager seat...in almost perfect conditions with only 6500km on the car.
I'm sure that with 20 000km on the car and excellent conditions it could do 13.999.
manual-->6MT
dmac: Do you have a link for the guy that did 14.2 with his TL? I find it impressive since that car has less tork and less hp than the coupe.
heres what my coupe is doin with minor mods and stock tires.
2003 G35 Coupe AT(Silver)
Injen CAI
Borla cat back exhaust
Straight Pipes
Hyper Grounding 6 wires
1/4 13.858 MPH 99.96
60ft 2.132
Injen CAI
Straight Pipes
60ft 2.132
I'm pretty sure Jasonperformance has a tricked out 350Z.
AV6, those are some quick times for the Sedan. Where did you get those numbers?
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
2003.5 5AT
Premium Package
Tire/Wheel Package
Kahboom,
I've seen one guy ran 6MT sedan stock (removed spare/tools with 1/4 tank 93 octane gas) at Great Lakes Dragaway track 14.163 on BFGoodrich g-Force T/A KD (245/40/18) with 27psi. When I asked he said he was stock with 3800 miles on it.
Other times:
Sedan members here ran stock the following:
3point5SE_Auto - 6MT sedan 14.28
BobbyD - 6MT sedan 14.33 @ 98.62 (600' above sea level)
normjack - auto sedan 14.35 with K&N Air Filter replacement only
Magazine times typically run 14.6 for auto sedan with full tank of regular gas, attached equipment and nothing removed. People running on the track getting usually better results due to higher octane gas with less then 1/2 tank, weight reduction and good launch.
Car and Driver by the way showed Infiniti G35 sedan 6MT running 14.2 sec @ 99 mph
Here is the link
Other times:
Here is the link
