? about shifting (my first week learning)
Old Jun 20, 2007 | 03:24 PM
vtb11's Avatar
when shifting gears, should i still be pressing the gas slightly when i apply the clutch? or should i be completely off the gas?
and does it apply the same way when i release the clutch? to make the ride smoother, i know i have to ease the gas as im releasing the clutch in first and 2nd, but wasnt sure if it was good/bad to in 3rd and higher
i gotta get these down before i break my new car!
Old Jun 20, 2007 | 03:36 PM
izmir41500's Avatar
G35driver Addict
clutch in - shift into first gear - release clutch slowly while giving a little gas near engagement - clutch out - gas only at this point
to shift into second
no gas - clutch all the way in - shift into 2nd - release clutch slowly while giving a little gas near engagement - clutch out - gas only at this point
repeat.
Old Jun 20, 2007 | 05:18 PM
vtb11's Avatar
repeat.
ah, the no gas part before clutching into 2nd is what i was lookin for... at the moment, i was still pressing the gas slightly when pressing the clutch while in 1st... time for a test drive
thanks~
Old Jun 20, 2007 | 05:25 PM
izmir41500's Avatar
G35driver Addict
shifting into 2nd is similar to getting started in first, but with less gas. 3-6 i don't push the gas pedal until fully engaged usually. just depends on your driving style. practice and you should be able to shift smoothly.
while you're fully engaged in a gear you don't want to be on the clutch. you can also read about techniques on the web. heel-toe, toe-heel for more advanced stuff.
Old Jun 20, 2007 | 07:25 PM
bassholic's Avatar
It's the MOMO shift **** and pedals that are giving you trouble....
Old Jun 20, 2007 | 08:01 PM
vtb11's Avatar
my momo shift ***** and pedals arent on yet, i bought them, just havent installed
Old Jun 21, 2007 | 10:57 AM
watsgoodG's Avatar
practice...ive had my car for a year and im still getting better every day jsut takes time
cmesidewayz
Sep 29, 2015 09:28 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Gwhut?
Sep 4, 2015 11:10 PM
