Is your steering wheel centered?
Old Jul 1, 2007 | 10:22 PM
bocatrip's Avatar
I have had numerous alignments in the four years of ownership, and although my specs end up within the limits, I usually have my steering wheel off centered pointing very slightly to the left (Let me emphasize very slightly). I'm willing to assume this is due to most road and highway grading going to the right side and the steering trying to compensate by going left. There is no pulling at highway speeds. I am somewhat obsesive compulsive so of course this bothers me somewhat. Does anyone else find their steering wheel somewhat off centered on straight highway trips or am I just too much of a perfectionist?
Old Jul 1, 2007 | 10:35 PM
Beebo's Avatar
never like that on the G but it was like that on my moms Z!!!
Old Jul 1, 2007 | 10:46 PM
kernel's Avatar
SEC > Big 12
that would bother me too, my old car was mis-aligned like that. Try going to the stealership or a shop that can fix it and emphasize what you want fixed.
Old Jul 2, 2007 | 01:51 AM
Algy's Avatar
my car is lowered on 350zh techs and it does that. got it align and it still does that???
Old Jul 2, 2007 | 02:43 AM
CHIZELD's Avatar
Love Poker!!!
I am the same way, I had my car lowered on my swift springs and then got an alignment in santa clarita, ca and my car steering wheel was still a little off centered. Then I had my car re-aligned and the problem is now gone. I have to have things close to perfect.....
Old Jul 2, 2007 | 02:47 AM
ttrank's Avatar
Grocery getter
Sounds like you need a new alignment shop. Network alignment out here does mine and it's always spot-on.
Old Jul 2, 2007 | 04:26 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
happens to my car all the time, and i align it myself, the G is tricky to get the steering wheel perfectly straight.
-GP-
Old Jul 2, 2007 | 08:47 AM
bocatrip's Avatar
-GP-
I've had 2 different Infiniti dealerships doing the alignment and neither can get it straight. I was told to have the gas tank full for accuracy which I always do. The next time, I will ask to sit in the car while they do the alignment to see if that changes the equation.
Old Jul 2, 2007 | 08:49 AM
gto2050's Avatar
You need to tell the people aligning the car that the wheel is off center. When they align they lock the wheel into a straight ahead position. It can be relatively easily adjusted back to center. Mine is spot on after an alignment. Now my 68 GTO, that's another story!
Old Jul 2, 2007 | 03:06 PM
bocatrip's Avatar
[QUOTE=gto2050]You need to tell the people aligning the car that the wheel is off center. When they align they lock the wheel into a straight ahead position. It can be relatively easily adjusted back to center. Mine is spot on after an alignment. Now my 68 GTO, that's another story![/QUOTE
I specifically brought my car in to center the steering wheel. It had already been aligned. That was the only reason it went on to the alignment rack. What is their problem? Why can't 2 different Infiniti dealerships get the wheel to be centered? Is this Rocket Science? I also ask for a printout so that I can see that the toe specs are still within the limits.
Old Jul 2, 2007 | 03:14 PM
GeeWillikers's Avatar
Walking The Fine Line...
Mine's good to go, but I'm bone stock.
Old Jul 2, 2007 | 03:15 PM
bocatrip's Avatar
I've always been stock.
Old Jul 2, 2007 | 03:38 PM
EricIsKlumzyee's Avatar
if you do an alignment and adjust the front toe you need to lock the steering wheel (little device that wedge between the steering wheel and seat)
if the wheel is not centered when they make this adjustment then your wheel wont be centered..
- Eric
Old Jul 2, 2007 | 03:39 PM
MixturePinoy's Avatar
Mine is straight as well..... but my tires are oval!?
Old Jul 3, 2007 | 01:21 AM
HenryLee's Avatar
damn I know exactly what you mean!!!!
I had my car aligned couple of times and the guys cant
even get it. Once i had them in my car to show how
it was off and when he drove it mechanic was like
so small you can barely notice.. My AZZ i can tell
every time i drive..
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
Karnicle
Jul 23, 2015 05:08 AM
