Fuse question
Old Jul 30, 2007 | 05:12 PM
Gdood9's Avatar
Fuse question
Ok, I was going to post this in electronics and I feel like it doesn't quite fit there, but if it does moderators feel free to move this thread.
Soooooo....to my question. Does anybody know which fuse controls power to my gauge cluster? Thanks.
Old Jul 30, 2007 | 05:54 PM
Memphoman's Avatar
this is what I found in my manual, for an 07
UNIFIED METER CONTROL UNIT
 Speedometer, odo/trip meter, tachometer, fuel gauge and water temperature gauge are controlled by the
unified meter control unit, which is built into the combination meter.
 Shift-up indicator is adopted in the combination meter (M/T models). Setting of shift-up engine speed
(rpm) can be set with odo/trip meter.
 Odo/trip meter and A/T indicator segments can be checked in self-diagnosis mode.
 Meters/gauges can be checked in self-diagnosis mode.
POWER SUPPLY AND GROUND CIRCUIT
Power is supplied at all times
 through 10A fuse [No. 19, located in the fuse block (J/B)]
 to combination meter terminal 21.
With the ignition switch in the ON or START position, power is supplied
 through 10A fuse [No. 14, located in the fuse block (J/B)]
 to combination meter terminals 22 and 23.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to combination meter terminal 18.
Ground is supplied
 to combination meter terminals 1, 24 and 25
 through grounds M30 and M66.
Kng0fHrts
Sep 15, 2015 05:40 PM
TheBay
Aug 27, 2015 05:08 AM
broke_as_ajoke
Aug 22, 2015 08:27 PM
Danielek
Aug 11, 2015 09:33 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
