Low speed road noise
Old Aug 2, 2007 | 03:17 PM
CedsG35's Avatar
I've noticed that my car is having lots of road noise from the front tires when I'm going 20-30mph. I'm lowered on tein basics about 1.5in in the front. Should installing a front camber kit help with the road noise? I'll probably have to get new tires soon since I'm around 19k on the oem's, but just wanted to see if I can at least get rid of the road noise a bit for now. Thanks
Old Aug 2, 2007 | 04:28 PM
Deezflip's Avatar
once you have tire feathering, the rumble stays. I heard of people remounting tires on opposite sides, eventhough it helps, but they said the noise is still there.
Old Aug 2, 2007 | 04:52 PM
bocatrip's Avatar
Getting new tires (non-directional) will lessen the noise, but the roar will be coming back after 8-9,000 miles once the feathering sets in again. Remounting the tires and flipping them only slows down the feathering but will not eliminate it.
Old Aug 2, 2007 | 05:30 PM
oscottio's Avatar
i'm lowered too...and when ur lowered, ur car makes more road noise anyways. but i noticed that when my oem tires were worn, they made more noise during low speeds. time to change tires =)
Old Aug 2, 2007 | 07:17 PM
CedsG35's Avatar
so are you guys telling me that my front camber kit won't help reduce my road noise? If this is the case then do any of you know a place where I can get 2 front tires for my oem 19's for a good price? Thanks
Old Aug 2, 2007 | 07:19 PM
izmir41500's Avatar
G35driver Addict
yes basically once your tires are feathered, the noise will stay. i had stock suspension and my tires were roaring at 22k miles. check the marketplace for tire vendors. i'd wait until you need to replace all 4 if you have good tread still.
Old Aug 2, 2007 | 07:35 PM
CedsG35's Avatar
Damn! oh well, does anyone have a set off used tires with some good tread left that they are willing to part with? I'm located in Woodland Hills CA.
Old May 6, 2008 | 01:14 AM
eaurouge's Avatar
front camber kit will help once you get a set of tires. kinetix should be the best cuz it gives postive camber (but it's not readily adjustable). most of the other "sliding" kits (megan [which i have], cusco, ichiba, etc) only give more negative camber. those are good for racing and autocrossing but they're crap for everyday driving cuz of the feathering and excessive tire wear - not to mention they come out of alignment easily.
Old May 6, 2008 | 05:14 AM
nutt's Avatar
its your oem tires they wear about 18k and have alot of road noise. im pretty possitive it has nothing 2 do with your drop
Old May 6, 2008 | 07:40 AM
GR8TG35's Avatar
Summer performance tires are noisy period. The OEM Michelin Pilot Sports that came on my 04 G started to get noisy around 10,000 miles....after that, it was painful driving the car without the radio turned up.....
I replaced them, and the new Michelins were quite to the point I wasn't sure they were Summer Performance tires......but they are starting to make noise again after 7,000 miles.
Worn tires or unevenly worn tires will always make more noise.
Old May 6, 2008 | 08:23 AM
dR6's Avatar
dR6
Also inspect the tires thoroughly for nails. My brother complained about road noise for the longest time. Then he noticed a nail in the front tire. Once he had it plugged, the noise went away. Not a likely scenario here, but it's worth a shot.
rezendvous420
May 31, 2020 01:26 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
rping
Jul 26, 2015 09:53 PM
ddietz97
Jul 26, 2015 06:16 PM
