Shifter... Problem maybe??
Old Aug 10, 2007 | 08:22 AM
o0amazinazn0o's Avatar
Whats up guys, been driving my G for a few days now.. I might be just paranoid or something.. but is it normal for the shifter to have a slight vibration while in neutral? Its not even like a vibration.. more like it has a little movement or something...Or is it something serious?
Old Aug 10, 2007 | 10:01 AM
TheKnite's Avatar
My shifter vibrates a lot too since it's a direct link to the tranny. Make sure the car runs as it should and you're able to shift. Mention it to the dealer next time you're changing your oil, to make sure it's normal and that you'll be covered in the future just in case. Enjoy.
Old Aug 10, 2007 | 01:58 PM
Memphoman's Avatar
make sure UR NOT using the shifter for a hand rest, can be detrimental to synchro's.
Old Aug 10, 2007 | 03:44 PM
sliq's Avatar
please expalin? i rest my hand on my shifter a lot
Old Aug 10, 2007 | 03:50 PM
dofu's Avatar
20 Year Member
Get a solid tranny mount if you can live with the major vibrations moving to your chassis instead of the shift ****.
Old Aug 10, 2007 | 05:30 PM
Gdriver916's Avatar
Well it's only obvious. You put some strain on the syncros when your hand is constantly on the shifter because the shifter is directly connected to your tranny. I've got the same nasty habbit. Still do at times to be honest
Old Aug 10, 2007 | 06:07 PM
Thanks for the help guys.. this forum is much better then the last one i was with wen i had my honda..
But.. yes it shifts perfectly smooth into every gear... so im glad its all normal..
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
