Airbag light flashing??
Old Aug 10, 2007 | 03:57 PM
DOCSG35's Avatar
Exclamation Airbag light flashing??
This morning I started my G, and the frickin airbag light kept flashing and continued to flash while driving. Has anyone else had a similar problem and does anyone know what the problem is??
BTW, I own a '05 G35 6mt.
Old Aug 10, 2007 | 04:47 PM
Memphoman's Avatar
the actuall "flash" sequence points to a particular malfunction. It should come on for 7 sec the go out, trouble is indicated if on for 7 sec and then flashes every .5seconds. Still in warranty? have dealer check it.
Old Aug 10, 2007 | 05:02 PM
ak808's Avatar
You could try the key method to shut it off. It may reappear though. I forgot the exact process but if you search it should be on here somewhere. I know it involves turning the key to the on position (not starting the car), wait for a blinking light to stop (can't remember which one) and then shut it off and repeat this process 5 or 6 times.
Old Aug 10, 2007 | 06:07 PM
Gilley's Avatar
Mine flashed and after a scan at the dealer, it turned out to be a defective passenger seatbelt mechanism.
Old Aug 10, 2007 | 06:50 PM
LjN_728's Avatar
If you've never messed around with the center console area, take it back to the dealer and have them check it out. Flashing the system may not be a good idea if the airbags are indeed defective.
Old Aug 10, 2007 | 06:53 PM
DHCrocks's Avatar
did you work on the car recently. if you turn the ignition on while one of the airbag plugs are out then it'll flash even after you plug it back in. there's a reset trick on this forum. check the stickies.
Old Aug 10, 2007 | 08:22 PM
DOCSG35's Avatar
Thanks for the help guys! I'll take it to the dealership and have them fix it.
Thanks again!!!
Old Aug 10, 2007 | 10:15 PM
madscientist's Avatar
Thanks again!!!
good idea, airbags are one of those things you want to make sure work.
Old Aug 11, 2007 | 12:18 AM
Meth68's Avatar
Did you do anything to your car? I just redid my whole a/v inside and after messing with the steering controls to work with my carpc my airbag light came on (steady not flashing) I took it to a friend at nissan to reset it real quick.
Luisgalvan33
Jul 19, 2018 08:16 PM
flytim3
Sep 5, 2015 01:23 PM
leli_11
Aug 10, 2015 08:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
