Help: Loud popping noise in rear when turning
Old Aug 15, 2007 | 03:58 PM
g35man04's Avatar
CLUB MODERATOR
Like the title says....I have a popping/clicking sound coming from the rear of my car when i turn or hit just a slight bump.....
I have recently had Hotchkis Sways, GT spec rear lateral bar and Rear Tie brace put on the back as well my SPC camber kit since i have Tein Basic Coilovers....But i have had this noise going on for about a month....i dont know if its some thing my axles or what...I have had all the bolts in the back Torqued down to spec and about a month ago I pulled off my Xo2 exhaust and went back to stock because I have HKS coming in the mail. Would putting my stock exhaust back on cause a noise?? I was thinking maybe the hangers are worn out but i only have 25000 miles on my car.
I saw a bulletin about the axle needing grease....but not sure if that is really the issue.
Old Aug 15, 2007 | 04:03 PM
izmir41500's Avatar
G35driver Addict
i'm assuming you have looked under your car to see if anything is broken? end-links, toe-bolts, etc.
Old Aug 15, 2007 | 04:08 PM
g35man04's Avatar
CLUB MODERATOR
GS motorsports just put on my SPC camber kit and toe bolts as of last week...was still doing it when i left. So i dont know if its the Sways which i doubt.....the GT spec bars are torqued down to spec. So i am wondering if its my tein coilovers...but with those i have had them for at least 6-7 months now and havent had really any noises until the past month and half....I think it may be my OEM Exhaust.....either the hangers or something...but i will have my HKS installed within the next week or so...hopefully that will fix it if it is the exhaust.
i am not sure about the end links though since they were not replaced when my hotchkis went on....but then again the setting i put them on may have caused the noise as well. Since my car is in the shop today at GS motorsports i have had them put my sway bars on stiff and torque down everything again just to make sure.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
Wayne9011
Jul 27, 2015 11:25 AM
justgotg35
Jul 19, 2015 12:33 PM
