2003 G35 - Problem with keyless entry locking drivers door
Old Aug 20, 2007 | 07:21 AM
Bumrush's Avatar
Guys, I don't know if this is electrical, mechanical or related to the keyless device... Keyless entry seems to be working perfectly fine, it opens the trunk, opens the locks and sets the alarm.. However, the drivers side door does not lock. It wants to lock, but it gets stuck about a 1/4 of the way through. The passenger side locks fine.. When I manually lock the door with the key it works fine. Anyone see this before?
Old Aug 20, 2007 | 08:12 AM
Plat04G's Avatar
Ha. This just started with me when I got back to my car at the airport yesterday. I kept pressing the unlock but my passanger door would not unlock. Calling the service dept this morning for my appt.
Old Aug 20, 2007 | 11:19 AM
fabulustt7's Avatar
yeah my passenger door wont look either i have to manually lock it unlock it...when i use the key fob you can hear it trying to lock/unlock
Old Aug 20, 2007 | 12:47 PM
*BlackG35Coupe*'s Avatar
WTF I Just started having the same problem! My driver's side window stopped working a couple months ago, a very common problem from what I've read on the forums. A couple days ago my passenger side lock stopped working as well, I have to manually open it. I'm starting to get pissed at all these electrical problems, I'm just out of warranty and if this is a known problem Infiniti should issue a recall or something. Anyone else having the window or door lock problem??
Old Aug 20, 2007 | 12:57 PM
Memphoman's Avatar
fairly common problem, even with the Maxima's I replaced my door lock actuator for about $105 from Nissan dealer. Pretty easy, just time consuming, remove door panel and window glass and back together.
Old Aug 20, 2007 | 01:16 PM
hfgreg's Avatar
I had the same problem, dealer fixed it for a couple hundred bucks can't remember the exact price.
Old Aug 25, 2007 | 03:32 AM
imballin2day's Avatar
i have the same problem
Old Sep 2, 2007 | 10:01 PM
travie46's Avatar
Me too.. someone knows the part # of door lock actuator, because like blackg35coupe I'm starting to get pissed at all these electrical problems
power window motor, Door lock actuator
Old Sep 2, 2007 | 10:55 PM
Beebo's Avatar
same on my pass door still have not fixed it
Old Sep 2, 2007 | 11:00 PM
Bumrush's Avatar
Strange thing, miraculously the problem fixed itself for now....
Old Sep 2, 2007 | 11:06 PM
Beebo's Avatar
maybe not my door has worked a few times then quits agian
Old Sep 2, 2007 | 11:43 PM
Fassster10's Avatar
my door is the same problem, now its both doors, i have an 03 coupe WTF, this should not be common on our cars, Infiniti should offer a solution because it seems like a faulty workmanship...
Old Sep 3, 2007 | 12:13 AM
kernel's Avatar
SEC > Big 12
It is the door lock actuator...I had my passenger side replaced about 2 months ago 150 mi before my warranty ran out.
Hasanbaloch
Feb 29, 2024 08:45 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Tom_P
Jul 24, 2015 04:05 PM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
Chattzx
Jul 17, 2015 11:23 AM
