Driving a 5AT
Driving a 5AT
A couple dumb(sorry) questions I couldn't find searching.
1. If you floor it on a 5AT it shifts at redline right? So if you're at a track it's better to keep it in drive than tiptronic? And if so, does it shift at the redline or rev limiter?
2. Is it bad to overrev on a 5AT in tiptronic mode for the drivetrain? Like lets say 4th gear at 30-40mph. Because I'll notice if I have it in drive mode it is in 4th gear at those speeds (from what I can tell looking at the RPMs) I'm asking because I like to overshift to save gas when I'm in the mood for slow driving (like when I'm tired).
Thanks.
Thanks.
In manual mode, it will NOT shift until U move the selector, IF U don't, it will hit the rev limiter, and basically die till RPM drops about 1000, happens very quickly and really sounds nasty and feels like it too.
so true I've found out. It does redline really fast.
If your racing, you can control it better with tiptronic-- IE find that perfect shift spot right after 6500.
Yes if you do goofy shifts and use tiptronic all the time it will blow your tranny
Mine took a **** at 31k, 30k of those miles were tiptronic
If you are talking at the 1/4 mile track, leave it in auto mode. You can not physically shift as fast as the tranny. Do not pre load the TQ converter as it will actually kill some engine power at luanch as well.
Completely wrong dont leave it in auto
OK - so if your racing:
Leave it in manual mode for your launch. At about 5000RPM - throw it into Auto mode and just drive away. For the AT's and a 1/4 mile - your best brake torquing the car in 1st gear at the line, to get the converter closer to lock up - around 2600-2800 RPM - that is if you can hold it before it spins the tires.
As far as using manual mode, holding the RPM's'
a a little higher and making people think you've got an MT - it wont hurt anything at all, especially in the transmission.
Rick
Rick
Originally Posted by EuG35
...I like to overrev to save gas...
Rick
Rick
Originally Posted by sliderg35
OK, you lost me on this one. If you want to save on gas, you would want the RPM as low as possible (in the highest gear). If you are overreving, you might just as well cut a hole in the bottom of your gas tank.
Rick
Rick
+1 but definitely leave it in manual mode your whole way through and just learn when to shift your 5AT
