shaking problems
Old Sep 2, 2007 | 07:22 PM
cubanaso696's Avatar
shaking problems
i was driving today on the fl. turnpike and when i hit around 75mph my car started shaking like crazy as if the the car was about to fall apart. when i got on some traffic and slowed down to almost a complete stop then accelerated again the problem dissapeared this happened to me once before on another road my tires are all balanced did it recently i drive on that road all the time and never have that problem has anyone ever had this problem?
Old Sep 2, 2007 | 08:41 PM
vice_versa's Avatar
Pretty well known issues of the G35. Uneven thread wear, rear axle bolt being loose, bad alignment, out of balance tires.
Old Sep 3, 2007 | 04:34 AM
EuG35's Avatar
Wait, besides the rear axle bolt being loose, aren't those pretty much tire problems not related to the G35 specifically? As in it can happen on any car, RWD car in the case of uneven thread wear? Just asking.
Old Sep 3, 2007 | 05:30 AM
Beebo's Avatar
it may just be alignment or you need to balance you tires. as vice_versa said
Old Sep 3, 2007 | 12:30 PM
Andy2434's Avatar
+1 . . . Check the balance of the wheels/tires, first. Good luck!
Old Sep 3, 2007 | 02:32 PM
Gam3's Avatar
same thing happened to me when i was in a friends lexus IS
Old Sep 3, 2007 | 04:23 PM
metah24's Avatar
if you just put tires on and they're still shaking at highway speeds. Take the wheels off and checkthe balance again. IF its still good, take the weights off. Break off the tire and rotate it 180 degrees on the rim. Remount and balance again see how that does.
Old Sep 4, 2007 | 12:28 AM
the car hasn't been doing it lately it was just that one incident i took the tires to family tire today and the tires were perfectly balanced i didn't think that was the problem anyways since it stoped doing it right after i slowed the car down if it was a tire problem it will be a constant problem do you guys think i should bring it to the dealer and tell them about the problem or do you think they will just brush it off?
Old Sep 4, 2007 | 01:23 AM
MaidenG35's Avatar
How long have you had your s-techs on for? Could be your shocks getting weak causing the shaking or inner tire wear on the fronts maybe..that seemed to be the problem with mine..after I got new tires and Tein Basic coilovers, my car stopped shaking when it usually did at a certain spot.
Old Sep 4, 2007 | 02:40 AM
CHECKERED's Avatar
If the vibrations are only at a certain speed your wheels are out of alignment, other causes mentioned will produce vibrations at all speeds.
Old Sep 4, 2007 | 07:24 AM
g35rcr's Avatar
check your lug nuts
Old Sep 4, 2007 | 07:25 AM
g35rcr's Avatar
alignment will not cause the car to shake...if your lugs are loose it wont be noticeable until you go faster it will feel and sound like you have a flat
Old Sep 4, 2007 | 11:06 AM
ibelonginprison's Avatar
Resident G35Driver Pirate
Exactly
Not always true, it *can* be noticeable even in a parking lot, depending on circumstances. If it's finger tight vs if the lugs are only twisted on a couple turns.
I would take it past the dealership and at least have the problem noted in the service records. That way if something goes terribly wrong (like the whole rear end falling out or whatever) then you have proof that you notified the dealer of the issue.
That's just me.
Old Sep 4, 2007 | 11:28 AM
i think i'm going to take it to the dealership for my peace of mind it only did it once so it's very unlikely i could reproduce the problem i just hope they take it seriously
Old Jun 10, 2010 | 12:55 AM
Fongyd85's Avatar
2007 g35 coupe AT
Hey I have a similar problem but my car drives fine at high speeds. Only a few times when I am from a stop accelerating to about 35-40 mph my car starts shaking and the gear shift shakes. It feels like i'm driving over a bunch of smooth bumps. I feel like my car hits a small hump and then the engine or transmission starts bouncing and doesn't stop until I let go of the gas. But then when I press the gas again it's gone. I am on point with oil changes and use only plus shell gas. I have a little over 40k miles.
