squeaky clutch?
Old Feb 4, 2004 | 12:10 PM
jussdipping35's Avatar
squeaky clutch?
does ne body besides me have a squeaky clutch???
shieeet im only duece one......hehe
Old Feb 4, 2004 | 01:43 PM
ReDRoK8's Avatar
Re: squeaky clutch?
Me too. Just started doing it around 18K. I'm gonna take it in the dealer soon to see what they can do. I think it just needs to be greased or possibley have a bolt tightened. Peace.
-Jason
Laser Red '03 6MT
Old Feb 4, 2004 | 09:14 PM
nuttyprof's Avatar
Re: squeaky clutch?
i have that. was going ot try to spray some wd40 on there. i adjusted mine, so i dont know if the dealer would handle it. what do u guys think? or maybe ill adjust it back first
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Feb 4, 2004 | 11:49 PM
dopeymon's Avatar
Re: squeaky clutch?
put more clutch fluid in... its the same stuff that goes in the brake fluids... try auto zone and pour some of that baby in. Open up the hood and you should see somewhere to pour it in... you're probably like really low right now. First the clutch squeaks and doesnt feel as good anymore.... once it's empty your clutch won't even come back up or you wont even feel the friction point.
Old Feb 5, 2004 | 12:36 AM
RamboRami's Avatar
G35driver.com Moderator
Re: squeaky clutch?
make sure the squeak isnt coming from the sensor that moves in/out when you press the clutch all the way down.... take a flash light back there and look at the little button that gets pushed... mine squeaks because of that button making a clicking noise... just a thought.... so check that first and make sure its not the same "feature" that i have [img]/w3timages/icons/smile.gif[/img]
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Feb 5, 2004 | 03:36 AM
nuttyprof's Avatar
Re: squeaky clutch?
Rambo: say what? im confused. i did the clutch adjustment...pretty damn low too i must add. my clutch squeak when i press it all the way down. when i release it, for about 1 inch it squeaks, then the rest of the way, it is fine. what could this be? i go to jiffy lube and they fill up all my fluids i think...that should include the clutch fluid.
G35S 6MT
Technosquare ECU
6-wire ground kit
Old Feb 5, 2004 | 12:12 PM
RedefinedG35's Avatar
Re: squeaky clutch?
yeah i have the same problem too... it sounds like it's is from the pedal some where...
Old Feb 6, 2004 | 04:16 PM
RamboRami's Avatar
Re: squeaky clutch?
Oh ok.....so its different then.....
Well take it to the dealership and have it checked out... Use your 4yr/70,000 mile warranty! [img]/w3timages/icons/smile.gif[/img] heh
Old Feb 7, 2004 | 06:07 AM
nuttyprof's Avatar
Re: squeaky clutch?
yea, the problem is that since i adjusted my clutch, the dealer might blame it on me. so id rather not have the see it. ugh. means i have to adjust it back then i guess.
G35S 6MT
Technosquare ECU
6-wire ground kit
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
jbmw002
Sep 10, 2015 12:54 AM
TheBay
Sep 3, 2015 03:27 PM
