Please help me.............
I say suck it up and do an upgrade while you are at it!! Get the window roll up module and just take the door panel off to do the mod and remove the paper. If you work slow you will be fine. If you PAY someone to do it I GUARANTEE they will eff something up or scratch the panel up. Trust me on this!!!
Come on man, open the sucker up! If you can open the door to get in the car, you can take the panel off.
It will take you about 30 seconds. See attached - it is for a sedan, but the coupe is close. The trick is the cover (Part #5). Once you pry that off, 2 screws are visible. There is another little clip to remove where the inside door handle is. Just poke a screwdriver in it and pry up. Once those three screws are off, just gently pull the panel off starting at the bottom and work up the sides. The top part is just folded over the door - don't pry at the top - just lift up once the panel is free around the sides and bottom.
If you can check your own oil, you can do this.
This happend to me too ... it was an accident i went to grab it out of the window and it accidentally fell down in the door.. i was so mad!!!
but i just left it and forgot about it -- 2 years goin strong with a stupid flyer in my door...
Bottom line, dont worry about it.
So unless my window decides to stop working correctly my door panel will stay a virgin.
Well, In PA it is illegal to put ads on cars because it is personal property. Just like you are not allowed to put them IN the mailbox. I would find the company who did it and just let them know. If nothing is done, then just do a little threat(NOTHING BAD).
Thanks!
Thanks!
Originally Posted by htownboy
Yeah, but if it was your daughter at the prom, maybe it would have been better to let the bra alone a few more years?
I'm saying, my window works fine and the screws are still virgin!
