transmission and brake problems,
Old Nov 5, 2007 | 06:09 PM
cshih2's Avatar
these days, when i do the heavy brake i can feel the **** shakes badly,
does the brake system has anything to do with the trans?
Old Nov 5, 2007 | 07:16 PM
Gsouske35's Avatar
Pull the car out of gear when you break to avoid dropping into lower rpm's and stalling your car out
On serious note, im no mechanic, but if I took a educated guess, I would say the breaks and transmission are completely unrelated in this case.
Old Nov 5, 2007 | 07:55 PM
Beebo's Avatar
^^^+1
Old Nov 6, 2007 | 07:00 AM
g35rcr's Avatar
sounds like your BRAKES are warped and might cause the rotor to BREAK if you have cross drilled rotors. The car shaking can cause problems for your trans and engine mounts if it gets severe
Old Nov 6, 2007 | 07:14 AM
zx11pilot's Avatar
Brakes have nothing to do with the transmission.....
Most likely you have a warped brake rotor or possibly a stuck piston in one of your brake calipers. It might even be simple thing such as one or more tires being out of balance.....Or your entire ABS system may be shot
Old Nov 7, 2007 | 12:36 AM
cshih2's Avatar
i just replaced the HAWK this afternoon, the brake is alot better now!
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
newg37
Jul 26, 2015 09:32 AM
Lsantana757
Jul 20, 2015 09:08 AM
