need window motor intructions!
Old Nov 30, 2007 | 10:22 AM
imRACERX's Avatar
anyonje know where i can find instructions for driver side window motor install? thanks
Old Nov 30, 2007 | 11:37 AM
sliderg35's Avatar
Well, this is for the sedan, but it should get you close...
need window motor intructions!-window1.jpgneed window motor intructions!-window2.jpgneed window motor intructions!-window3.jpg
Old Nov 30, 2007 | 12:27 PM
imRACERX's Avatar
i cant remove the module assembly!
i remove all the bolts but it still come out. do i have to remove the bolts located in the center of module? i only removed the outer ones that fix the module to door. not sure whaT TO DO.
Old Nov 30, 2007 | 12:36 PM
XLRATOR's Avatar
I have the instructions that you need but its in a zipp file and I'm not sure how to put it here, pm me and I will send it you.
Old Nov 30, 2007 | 03:20 PM
imRACERX's Avatar
thanks but fixed~!
the problem was one of the guides didnt want to cooperate but i was babying it too much and didt loosing the right upper screw. when i did it fell apart but got it off. anyway, went to replace the motor once i was able to access it, turns out they sent me the passenger motor. i cursed for about 3.5 minutes then i figured i would clean the guides, wire, everything and what do you know..... it works better than new. i knew infiniti was full of shiit when they said i needed a new motor. since it worked but was chopy on the way up and down i knew somehow it could be fixed. anyway, i will go to autozone and demand my refund. at least it all worked out and didnt have to buy anything. thanks guys for the help.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
