Radio Memory Issues???
Old Dec 5, 2007 | 06:14 PM
ovrkast's Avatar
Hello All-
First off I'm new to the forums as I just bought a used 2005 G35 Coupe Automatic with/NAVI. I'm just learning all the things about the vehicle, and have come across an annoying issue. I've search about 50 pages of this forum and have not found what I was looking...so please be kind if this has been addressed already
So here is my issue regarding the radio. Everytime I turn on the car and take it for a spin, I would notice that my stereo sounds a bit off or muffled. I then press the "Audio" button and double checked my "Bass and Treble" settings and everything seems fine from the last time that I set it, but yet the stereo does not produce a crisp sound. My only way of dealing with this issue is that I would need to go back to "Audio", select the "Treble" and reduce the setting then increase it back to hear the crisp "Treble" notes. This happens every time I power the car off, and then power back on. It doesn't seem like it wants to hold the "Treble" settings unless I perform the method mentioned above.
What should I do? The vehicle has about another year of warranty left, and I'm not sure if the dealership will address this issue by replacing the head unit or anything else they need to do to correct the problem. Please advise.
Thanks in advance.
Old Dec 5, 2007 | 07:56 PM
Memphoman's Avatar
getting Lt/Rt seperation when it sounds muddied? I used to lose Lt/Rt, Ft/Rear seperations frequently on my Maxima, does sound change between disk and radio?
Old Dec 6, 2007 | 10:35 AM
ovrkast's Avatar
It's not the LT/RT separation. It's whenever I turn the stereo on that it does not retain the "Treble" and "Bass" settings even though it shows the settings as being correct. If I adjust the settings up or down, then you can tell that the quality has been enhanced. This happens with both radio and CD. I think the head unit will need to be replaced or something...but I've never experienced this before on any of my other vehicles in the past.
Old Dec 6, 2007 | 12:07 PM
Aquaman13's Avatar
From what I've experienced if you keep the bass or trebble under 5 which is the max, the settings will keep. It seems that maxing them casues the issue. I keep both at 4 and they stay.
Old Dec 6, 2007 | 12:28 PM
Gdriver916's Avatar
I have the same problem and I have already had my unit replaced at the dealer but it still does the same thing. I just keep it away from the 5 and -5 on both bass/trebble.
Old Dec 6, 2007 | 12:40 PM
giddyup69's Avatar
it's one of the joys of owning a g35.
Old Dec 6, 2007 | 05:04 PM
Memphoman's Avatar
I keep mine on +5 both Bass and Treble, no problems thus far, always kept them on +5 in my Maxima too. Did have my HU replaced on the Max and changer replaced on the G
arora_g35
Apr 16, 2026 02:52 PM
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 20, 2015 07:20 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
kd03g99
Jul 30, 2015 11:24 AM
