Anyone had this problem with fuel tank?
Old Mar 3, 2004 | 10:49 PM
Mani's Avatar
Half the time I go to fill up at a gas station, I can only fill my tank to half full. Try as I might, it won't let me squeeze any more in. Other times I'm able to fill to full tank, no problem. Really weird. Anyone else had this or heard of it? Is there a fix?
Old Mar 3, 2004 | 11:33 PM
Aznteazer's Avatar
Re: Anyone had this problem with fuel tank?
is it just your needle?
safe to just take to ur dealer
Coupe 6-spd Twilight Blue/Black Premium
Old Mar 3, 2004 | 11:55 PM
xlr8ing2infiniti's Avatar
this happened to me alot when i first got my car. dont sqeeze the lever all the way, something about having too much pressure coming out of the nozzle doesnt let the tank fill all the way. as long as u dont pull the trigger thing all the back youll be fine
2003 G35 Coupe - Ivory Pearl w/ Willow Interior - Premium Package - Sport Package
Old Mar 4, 2004 | 01:02 AM
narkotic's Avatar
This happened to me tonite actually.. Typically happens at "ultramar" gas stations for me...
VortechSupercharger
TeinBasicCoilovers
Volk 19" GT-7Gunmetal 19x9.5,19x8.5
BridgestoneS0-3 245/35,275/35
EBC GreenstuffBrakePads
RogueEngineeringShort Shifter
NismoGTTitaniumShiftKnob
Old Mar 4, 2004 | 01:18 AM
Mani's Avatar
Don't think it's my needle cuz my nav says the same thing. I'll try using less pressure on the handle, but I usually don't pull the lever all the way anyways.
I did notice this doesn't seem to happen at certain gas stations.
Any other ideas?
Old Mar 4, 2004 | 02:36 AM
DaNo_G35's Avatar
it happened to me the other day...it stopped before fueling full tank...i dont know why....its weird
Old Mar 4, 2004 | 09:57 AM
tpware's Avatar
we have a saddle tank setup, its been discussed ALOT here. if youre parked on an inclined or tilted, you may have problems. It also may happen after spirited driving. Basically, one side isnt venting to the other.
If you fill alittle more slowly, it helps. But once you've clicked off early, there isnt much you can do to fill it the rest of the way. At least not for awhile I've found.
Old Mar 4, 2004 | 10:37 AM
Roller_G's Avatar
That happens to me from time to time. The fix for me is to tilt the pump at different angles.
99 Supercharged PY Civic SI 13.8@101mph
03 BO G35 xx@xxmph...to be continued...
Old Mar 4, 2004 | 11:42 AM
clm288's Avatar
Mine was the gas tank sensor, something like that. They had to replace the sensor. I had to take the car in with a low tank of gas for them to replace it. I believe they dropped the tank. Good luck. I bet yours is the same thing.
Old Mar 4, 2004 | 10:32 PM
Mooser's Avatar
It could be something as simple as the sending unit. If your capacities are correct on fill up, but the gauge indicates otherwise, that could be the problem. That would be a repair under warranty, and you would be covered. It might be worth looking into.
2003-G35C-5AT Laser Red/Black/Prem/XM/Tint/Chrome 17's/Black Badged
Old Mar 4, 2004 | 10:34 PM
ryoken's Avatar
It's happened to me once at an Ultramar.
Old Mar 4, 2004 | 11:54 PM
poolshark's Avatar
Hey, all. I took my ride in 2 weeks ago because my fuel gauge would never read "full" whenever I pumped gas up until the auto shut-off occurred at the pump. The description on my invoice read: 'FUEL SEND. UNITS NEED REPLC., INSTALL DR SIDE PASS SIDE/INSTALL FUEL PUMP PAS. SIDE'. So, under warranty, the dealership listed the following parts (for those who are interested...and can make sense of the listing):
Qty Parts
(1) Sender Unit - Fuel Gau - 25060 - AL511
(2) Ring-O Fuel Gag - 17342 - 01A00
(1) Pump Compl - Fuel - 17040 -CD000
It seems that Mooser is right on the money....as was another poster.
'03 G35 C Prem Pkg, Navi, Aero, Performance Wheel & Tire Pkg
Old Mar 5, 2004 | 02:00 PM
PTownG35's Avatar
Ive had this problem also. The dealer fixed this for me yesterday. It's a fuel gauge sensor that they need to replace. I filled up this morning past the F indicator with no problem.
Old Mar 5, 2004 | 09:02 PM
SpcyG's Avatar
Yes, yes, yes!! My car has been to the dealer 3 times! There is some kind of manufacturing problem that Infiniti hasn't admitted to yet. Report it to your dealer & Infiniti Consumer Affairs.
Old Mar 5, 2004 | 09:31 PM
GR8TG35's Avatar
I agree with everybody that the fuel gauge is far from accurate as far as reading full.
However, if your car is not filling up all the way should no way be related to the tank sensor/gauge. I think the problem here is in the neck design of the fuel tank.
some gas stations, (especially the ones on the main highways) seem to pump at a faster rate....therefore the fuel is being pushed into the tank...the splash back caused by this sometimes trips off the fuel nozzle as if it reached the full mark in the tank....
In actualitiy the splashing may have left you less than full and therefore everyone assumes its the gauge/sending unit....
whenever my car stops taking fuel..I can always add at least a half to a gallon more fuel...since I fill at the same station all the time...I have gotten a feel for the real full of our tank.....
Many will disagree I'm sure....but the gauge or sending unit is not what dictates how much fuel your car will hold...just the amount of fuel remaining in the tank....<font color=blue>2old4this</font color=blue>
04 cpe ivory pearl/willow/5at/prem/sport wheel pkg/clear corners/Piaa's/MTEC H4 Super White fog/highs
