Well Guys 881 Miles on my G35c...Squeeling breaks!
Old Mar 8, 2004 | 05:33 PM
MaevRok's Avatar
I just called to make an appointment and the guy gave me the bs of this will happen from time to time. so i was like w/e...Another thing happening is a weird thump when switching from 2nd to 3rd in semi-manual mode on my auto. its comming from the rear of the car. he said he needed his service manager to take a ride with me cause that was weird. what do you guys think?
Old Mar 8, 2004 | 10:41 PM
03G35Black's Avatar
Re: Well Guys 881 Miles on my G35c...Squeeling breaks!
my brakes squeal like crazy. its embarrassing. i had the recall work done, but they still squeal.
Old Mar 8, 2004 | 10:47 PM
luvmyG35C's Avatar
Haven't had either of these happen to me and I just hit 1050 miles.
2004 Brilliant Silver Auto Coupe Leather
7 Wire Hyperground
Z-tube/JWT Popcharger
5% Tint Rear 30% Door
Injen Exhaust
Old Mar 9, 2004 | 12:23 AM
uheenada's Avatar
well i have to agree 100% with MrElussive...
for the manumatic mode, you are sacrifice "smoothness" for a "faster shifting"... and sometimes you get jerks/thumps shifting 3rd to 2nd or 2nd to 1st obviously due to gear ratios... and don't sweat about it... it's normal and won't hurt your engine/tranny...
and also for the brakes, try high pressure water and if still squeeks then have the dealer check it... but i highly doubt there's something wrong with brakes with only 881miles on it.. mostly brake dusts stuck on pads/rotors...
Old Mar 9, 2004 | 12:35 AM
MaevRok's Avatar
thanx for the replies guys! i washed the breaks up a bit today and squeeling is gone!
Old Mar 9, 2004 | 08:14 AM
startertan's Avatar
I just started squealing around 18,000 miles. It would seem that the rotors are okay and the brake pads look like they're good. Isn't it only a problem if they squeal while driving not while braking...although it is annoying to be braking and squealing.
Old Mar 9, 2004 | 08:35 AM
Ggirl's Avatar
My G had sqealing brakes and they replaced the pads in my oil service. The squealing breaks haunt me though... Had the same problem with a BMW I had. I think I changed the break pads about six times before I traded it in.
G35C Desert Platinum/Willow Leather 5AT Aero Pack Premium Pack
Old Mar 9, 2004 | 08:40 AM
EX250's Avatar
I try not to use my brakes and just downshift as much as possible latley...my brembos have been squealing for about 4-5 days now, only from the front right wheel. I just dont hit the brakes hard enough to make them unless I have to....hehe I love 6 speeds. Anyway, I'll have it looked at when I go for my new spoiler and front bumper at the Infiniti dealership, hopefully I'll find out whats wrong.
2003.5 G Coupe premium. 6MT Black/black No navigation. No spoiler, yet.
Old Mar 9, 2004 | 08:45 AM
dgbos's Avatar
Mine squeel while driving and not braking sometimes. The squeel a lot in wet weather.
Old Mar 9, 2004 | 02:23 PM
sixone's Avatar
Took me until 8,200 miles till I heard my first sqeak..washed my car and now its gone. Also the MM shifting is normal as everyone else has said.
G35 Coupe Brilliant Silver/Graphite/Premium/Aero/ Blizzaks and 17's till March /
Old Mar 9, 2004 | 02:42 PM
KAHBOOM's Avatar
MM shifting will get better with time and once you get used to what are the optimum shift points according to your speed. My shifting also got smoother when I installed my grounding kit.
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Mar 9, 2004 | 02:50 PM
Gyromight's Avatar
I've noticed the brake pads they put on the Gs produce a lot of brake dust. A LOT more than my previous car where I had the Metal Matrix pads.
2004 G35 Coupe Prem / Aero D. Plat/D. Graph
Old Mar 9, 2004 | 02:51 PM
GX9901's Avatar
My car's at 7000 miles and the brakes did sqeak a little bit in extreme cold weather. It seem to have subsided but does come back once in a while. I'm not too worried since Infiniti will replace it if it does go bad. I actually hope my brakes reach "replaceable" condition soon so I can get some (hopefully better) new pads installed.
2004 G35 Coupe Diamond Graphite/Graphite 5AT
Premium, Nav., 18" Wheels, Z-Xtreme Hyper Grounding Cables,
K&N filter, Clear Corners, 350Z Aluminum Pedals
Old Mar 9, 2004 | 02:57 PM
cleanstar's Avatar
I had the same problem. Screeching from 5mph to 0mph. I received a letter from Infiniti & was allowed to get service for the noise. The dealer replaced the rear rotors & pads. Noise was still there. About 2 weeks ago I took back to the dealer & there was a new fix out for the front brakes. They replaced some sort of plate that attaches to the front pads. Silence at last!!!! I have the auto, I dont know if the Brembos are covered for this service campaign. If you need any more info, I can give you the number to my service tech. Just let me know.
