Brake Update
Mar 9, 2004 | 03:07 PM
2-23-04 Outer shim update
A lot of G owners have been complaining of brake noise. My G was finally fixed after three times @ dealer. There is a new fix for the non Brembo brakes. There is an outer shim update for the front brakes, but pads have to be less than 3millimeters before they will fix. If you complain enough, like I did, they should get you the fix.
Reply 0
