fuel spillage
Old Jan 29, 2008 | 01:58 PM
filthyg35's Avatar
fuel spillage
I was filling up my g over the weekend..don't normally top it off, but this time I tried squeezing out another 1/2 gallon or so...then all of a sudden the fuel came pouring out all over the place and on me!!! I was pretty pissed to say the least...should this happen...isn't there a baffle to keep all the fuel from pouring out??? well I ain't gonna do that again..I lost more on the floor than what I put in!!!
Old Jan 29, 2008 | 02:02 PM
patman530's Avatar
i think most gas pump hoses have a sensor that cuts it off when it gets close to being full, unless you pulled up the rubber sleeve... and kept pumping, if so that's your problem
Old Jan 29, 2008 | 02:04 PM
filthyg35's Avatar
I didn't...that's the problem!! thanks for the reply
Old Jan 29, 2008 | 02:51 PM
Drox's Avatar
I think it depends on the gas station. I know that when I fill up at a particular gas station, it starts to spill out before the pump even stops. Needless to say, I have ceased going to that station to fill up.
Old Jan 29, 2008 | 04:01 PM
Curt G's Avatar
Wait, you're saying that the pump stopped and then you tried to force more gas in and it overfilled? Isn't that just physics? Sorry it happened. Glad you won't try it again.
Old Jan 29, 2008 | 04:03 PM
in2win's Avatar
you topped off and your mad that it came gushing out The pump and the tank dont have a brain, g35 drivers DO thats why were on here....
Old Jan 29, 2008 | 04:45 PM
GR8TG35's Avatar
Once the pump cuts off automatically, and you try to add or "top off" your tank, the gas will eventually spill over. You need to know how much extra you can squeeze in.
I usually can get about $1.50 more once the pump shuts off. any more, and I'm wearing it as well.
Pain in the A$$ cleaning it off your car, rewaxing, and still smell gas for a couple of days...
Old Jan 29, 2008 | 04:53 PM
Callaway's Avatar
You overfilled, the gas spilled over and you are mad at the car? WTF?
Old Jan 29, 2008 | 05:10 PM
VCG35's Avatar
Old Jan 30, 2008 | 09:42 AM
filthyg35's Avatar
you guys are too funny...I just didn't think it should come pouring out...I really didn't over fill it much..maybew less than a dollar...I know it's my fault!! thanks for the spanking...
Old Jan 30, 2008 | 10:38 AM
g7x5's Avatar
yeah usually i fill until it stops, then wait a sec for the gas to go down the tube then fill it up some more until it stops. But one day i went to another station and their sensors didn't work so well, so when i went to top it off it came gushing out. It really depends on the pump and if the sensor work properly. You'll just have to figure out which pumps work and stick to those.
Old Jan 30, 2008 | 11:41 AM
07G Coupe Chick's Avatar
I ALWAYS top off... try letting the gas settle before you try and put more... it also helps if you take out the hose and look in the tank. You can usually see where the gas is. I can normally put 1.50 to 2.00 more. Learned it the hard way too
Old Jan 30, 2008 | 03:40 PM
Gian124's Avatar
Recall
There was a RECALL on very early 2003 models for an issue quite similar to this. The dealership did the recall on one of my first maintenance services, and I do not recall the specifics other than it was a problem people had during refueling their Coupes. This may apply to you or may be coincidental.
Old Jan 30, 2008 | 04:40 PM
AdamJ's Avatar
User error. 1D10T error. Amazing how people can be so naive.
Old Jan 30, 2008 | 04:41 PM
AdamJ's Avatar
There's no way you are able to put an additional 2 gallons of gas in the car from the first time it stops.
