steering wheel shaking
Old Feb 10, 2008 | 12:44 PM
badboyz1187's Avatar
hey everyone i have an 06 coupe with close to 19,000 miles, the dealer changed my brakes about 2 months ago, when i step on my brakes now i get a funny slight vibration in the wheel, can it be that my rotors may need to cut?
Old Feb 10, 2008 | 01:12 PM
partyman66's Avatar
It's probably the rotors since you said it only does it when you hit the brakes. They're either warped or weren't cut when they did the brake job most likely.
Did the shaking just start, or has it done it since the day they did the brakes?
Old Feb 10, 2008 | 01:20 PM
it was happening a little before they did the breaks and i do a lot of highway driving from reading around im thinking its my rotors are they covered under warrenty?
Old Feb 10, 2008 | 01:59 PM
05GCOUPE6MT's Avatar
The rotors should of been CUT or Replaced. They did 1/2 the job.
Old Feb 10, 2008 | 02:07 PM
JOKER's Avatar
CLUB MODERATOR
if you had stock rotors installed they are prolly overheated and now need to be turned.
You will be having this issue all the time until you change your rotors.
Nissan/Infiniti rotors suck *****.
Old Feb 10, 2008 | 03:00 PM
silver g's Avatar
I would not reccomend turning your rotors. The never last quite as long. Just get some new ones and your problem will be fixed. Did your dealer charge you for any rotor work? If so you got hosed.
Old Feb 10, 2008 | 10:56 PM
Bimmer G's Avatar
Infiniti brakes lasted me just over 10k. Sounds like you need to uprade or replace your brakes. Stoptech make a upgraded brake kit which includes rotors, pads, and stainless steel brake lines.
Old Feb 11, 2008 | 01:09 AM
nope i just paid for a brakes change
Old Feb 11, 2008 | 10:32 AM
partyman66's Avatar
How much did they charge ya?
You'll probably want to try to pay closer attention to the details next time you have work like that done on your car. Ask them specifically what they're going to do on the brake change, and have them put it in writing on the receipt/bill so that you have proof of what they said they would do.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
