coins falling behind ash tray
Old Mar 18, 2004 | 08:34 PM
dpoon's Avatar
Re: coins falling behind ash tray
so everythign is just clips? no screws?
Old Mar 18, 2004 | 09:17 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
You can remove the ashtray bin but then there's the plastic housing of the ashtray that holds the bin. I don't think the ashtray casing falls forward enough to reach behind it. I think you have to remove the center console to get behind the ashtray.
dpoon, yes. There are no screws, just clips....
Old Mar 25, 2004 | 02:50 PM
dpoon's Avatar
im sorry, but toward the back of my center console, theres screws holding it in on the sides.
but anyways, is it possible to take out the center console without taking out the part of the dash?
Old Mar 25, 2004 | 06:20 PM
dpoon's Avatar
so no one knows if i can take out the center console without taking off the dash?
Old Mar 25, 2004 | 06:36 PM
docron1's Avatar
There shouldn't be any screws to remove dpoon. Take some pix for me to see. My center console doesn't have any screws to remove. It just pulls up from the rear.....
You shouldn't have to remove the dash to remove the center console.
Old Mar 25, 2004 | 06:39 PM
dpoon's Avatar
well mine has scews holding down the center console towards the rear on the sides. that are being covers by a little push on covering to hide the screws.
and when it seems like i was tryign to up it off, the part where the bottom of the radio and center console didnt seem like it would budge
Old Mar 26, 2004 | 08:45 AM
XCELR8's Avatar
I'll take it apart for you, but only if you let me keep all money I find back there hahaha
2003 BLK/BLK 6-spd Injen clear corners
Old Mar 26, 2004 | 11:47 AM
dpoon's Avatar
ok, you have a deal....
i dont think there is even more then a dollar back there.
Old Mar 26, 2004 | 05:49 PM
docron1's Avatar
When you lift the console up over the stick, there should be hook like things that will unhook if you lift the back part up and the front should dip under the hooks. Let me take some pix....hold on...
Old Mar 26, 2004 | 06:07 PM
docron1's Avatar
first do this...
Old Mar 26, 2004 | 06:08 PM
docron1's Avatar
then remove shifter, put shifter in neutral, pull up center console over shifter....
Old Mar 26, 2004 | 06:09 PM
docron1's Avatar
another unhook pix..
Old Mar 26, 2004 | 06:10 PM
docron1's Avatar
where little trolls live...
docron1's Avatar
feed your troll while you're in there....
Old Mar 26, 2004 | 06:12 PM
  #30
docron1's Avatar
You can't access the rear of the ashtray through the back of the ashtray even if you remove the black bin...
