Front Strut Tower Bolts
Old Mar 22, 2008 | 05:48 PM
425skyline's Avatar
Do the bolts on the front strut towers need to be torqued?
Old Mar 22, 2008 | 11:15 PM
xjonmo's Avatar
i don't know if they have to but if i remember off the top of my head the torque setting was about 38.
Old Mar 23, 2008 | 02:33 AM
425skyline's Avatar
if they had a torque rating then they would require torquing, right?
Old Mar 23, 2008 | 03:15 AM
sliderg35's Avatar
Pretty well every bolt on the car has torque specifications in the manual. If you want to make sure you tighten the bolts properly, use a torque wrench - otherwise, take the risk of loosing the bolt (if you put it on too loose) or breaking the bolt (if you tighten it too much). You can't go wrong by torquing!
Old Mar 23, 2008 | 03:21 AM
425skyline's Avatar
the manual you are referring to is the service/repair manual i can get on ebay or something similar right? Just a G35 coupe shop manual for 03-06.
Old Mar 23, 2008 | 05:27 PM
xjonmo's Avatar
you can download it here
https://g35driver.com/forums/faq-diy/107032-sticky-all-2003-2006-g35-coupes-service-manual-pdf-format.html
Old Mar 23, 2008 | 06:02 PM
425skyline's Avatar
damn it, i bid on the same thing on ebay for 99 cents and 5 dollar shipping LOL. if only you would have responded sooner haha... thanks though, i appreciate the responses.
so on the torque table basically any 12MM is torqued at 33? Same goes for any other diameter nut/bolt on that table? It's just standardized for all the bolts on the car I assume. I can't find the section for the front strut yet to see if they specifically say anything about those bolts.
Old Mar 23, 2008 | 08:06 PM
xjonmo's Avatar
there's a whole section for the front suspension. it'll say something like "for torque specs see this.." and you can click it and it will show a whole diagram of the front suspension with every component broken down for you. i just spent the weekend looking at this haha
Old Mar 23, 2008 | 08:57 PM
425skyline's Avatar
yeah i looked through the front suspension section and found it. Thanks a lot for the info... this is great stuff.
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
EPG35
Aug 16, 2015 04:52 PM
kinetek
Aug 3, 2015 04:25 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
cyrus32
Jul 18, 2015 06:22 PM
