issue w/ the auto up down window thing on the coupe
Old Mar 24, 2008 | 06:28 PM
LazyAlex's Avatar
u know that feature were..when u open ur g35 coupe door..the window rolls down alittle..then it rolls back up when u close the door.,..well..for some reason my driver side doesnt wanna roll down when i open the door..it rolls down about 1 cm...but..u once the door is open..u can push the window down to where the window is suppose to roll down till in the first place...make senese? is there a way i can fix this? reset any botton? or adjust it somehow? the passenger side is cool..it rolls down the right amount..but the driver side doesnt...thanks
Old Mar 24, 2008 | 06:37 PM
GISMO35's Avatar
I have had the dealer adjust this feature a few times on my coupe.
Old Mar 24, 2008 | 06:40 PM
simpson's Avatar
go to https://g35driver.com/forums/showthr...ght=window+fix
Last edited by simpson; Mar 24, 2008 at 06:41 PM. Reason: did not work using a quote
Old Mar 24, 2008 | 06:56 PM
GR8TG35's Avatar
The auto window down feature only lowers the window maybe 1/8". You can push it down a half inch or so by hand, but thats normal. As long as you can open your door without the window hitting, you will be fine.
If in doubt, let the dealer look at it.
For the record, the pass side window on my car lowers more than my side.
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
