Window Problems?
car:2003 g35 coupe
Problem: Passenger sometimes will not go back up after being down. I hear the relay clicking but no movement. I try both driver and passenger no movement and also tried the window lock to make sure it is not lock. Only the passenger i have problems. Any one know how to fix this. It make me mad
b/c one time it was snowing and i press the button to go down then it would not go back up
I have a friend with an 03 and he does this;
Instead of pulling the windows switch all the way up to the auto click position, he just pulls it slightly up and the window comes up... He said he had it calibrated once and it started again a few months later so he found this always works when it happens and when he pulls all the way up on the switch it always fails when it's acting up.
He says it does not happen often and this always works so he can live with it rather than taking it back to the dealer. I hope this helps.
