Engine dont start
Old Mar 27, 2008 | 05:06 PM
GoDaddy's Avatar
Engine starts then stops in warm
I have an 03 coupe.
Someone hit my car and left. Theres a bump around my left rear wheel.
So I brought to the garage to fix it.
3 days later, I came to pick it up. The body looks fine.
But everything in the car is reset (radio, etc). I guess they might have disconnected the batteries.
Now sometimes when i start the car, the engine start then stop ...
Old Mar 27, 2008 | 05:49 PM
nghiars's Avatar
it might be your MAF... sometimes as in when your engine is hot?
my MAF was doing that and car would cold start fine.. after it warmed up i would have to blip the throttle right after i start it to keep it running.
Old Mar 27, 2008 | 06:33 PM
partyman66's Avatar
We need more detail.
When you say that it doesn't start.... does it crank over when you turn the key but just doesn't fire? Does it fire up a little and then stall out? Does the starter turn but the engine doesn't make any noises as if it's being turned by the starter(you'd hear just a little electric spinning noise and perhaps some clicking, but no engine chugging sound).
Is there gas in the car?
Old Mar 27, 2008 | 07:06 PM
shadowCoupe07's Avatar
make sure the wires that connect to the battery is connected properly...sometimes the ppl ther forget to tighten it...thatz what happend to my old car...it kept stoppin when i was driving...and finally figured out that they didnt tight the wires properly to the battery...
Old Mar 27, 2008 | 07:44 PM
GoDaddy's Avatar
I turn the key, it starts, then a second after it stop.
Old Mar 27, 2008 | 07:46 PM
GoDaddy's Avatar
yeah it does does it when the engine is hot ...
Old Mar 28, 2008 | 11:08 AM
GoDaddy's Avatar
Its exactly what you say. I start the car in cold, it starts fine.
But when its warmed, I had to press on the gas to start the car or else its stops.
How did you fixed it? Bring it in to the dealer?
I went to the body shop that fix my car, they say its not there problem.... That they didn't touch anything since it's only body work.
Old Mar 29, 2008 | 09:39 AM
GoDaddy's Avatar
Help? looks like its a MAF problem, should I bring it to the dealer?
Old Mar 29, 2008 | 12:02 PM
silver g's Avatar
^ Depends r u modded and is your warranty still good?
Old Mar 29, 2008 | 12:49 PM
GoDaddy's Avatar
Im not modded, its stock, and no more warranty....
Terry_G35
May 9, 2020 01:39 AM
andyg35c1
Aug 29, 2015 03:37 PM
chinee
Aug 8, 2015 10:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
