clicking noise with camber kit
Old Apr 2, 2008 | 01:24 PM
roodawg2's Avatar
I just replaced my rear camber kit with spc. When the guy brought it down n puts it in gear n releases the clutch as if to stall out it makes a clicking noise that sounds like when your torquing your lug nuts. He never took the wheels off but thats what the clicking sounds like. I makes it when I get on it. Has anybody had this problem and can you please let me know what is happening please.
Old Apr 2, 2008 | 01:25 PM
g35man04's Avatar
CLUB MODERATOR
I have the problem with hitting un-even surfaces and the car jars right to left or vice versa I hear a clicking/popping sound...I have gotten to the point of living with it.
Old Apr 2, 2008 | 01:27 PM
lekker_droom's Avatar
my 350evos do it too. havent figured it out yet and dallas frame and alignment couldnt figure it out either.
hoping it goes away when the kw v2's get installed.
mine does it when i turn sharp, from the drivers side front.
Old Apr 2, 2008 | 01:32 PM
g35man04's Avatar
CLUB MODERATOR
I think mine may be my Tein Basic Coilovers on the car...
Old Apr 2, 2008 | 01:35 PM
irishsig's Avatar
I've got the same clicking prob in the right rear wheel when I initially step on the gas, but I don't have any mods except for wheel spacers.
Old Apr 2, 2008 | 02:15 PM
g35man04's Avatar
CLUB MODERATOR
interesting....questions questions......
Old Apr 2, 2008 | 02:47 PM
SukaZenki's Avatar
Could it be your sway bars? If you search on the forum about clicking noise; has been related to it and has been the bushings mostly. If not the sway bars; then search a thread on the TSB on the Axle's on the G. There's a TSB about regreasing the the Axles. Good luck.
Old Apr 2, 2008 | 03:11 PM
g35man04's Avatar
CLUB MODERATOR
yeah I have aftermarket sway bars. I re-greased the bushings again after reading that...still there though.
Old Apr 2, 2008 | 04:32 PM
damafuka's Avatar
sounds like axle click. theres a TSB for it
Old Apr 2, 2008 | 05:23 PM
g35man04's Avatar
CLUB MODERATOR
Yeah I have the car in the shop right now..I didnt figure they would warranty it because of how modded my car is...
Old Apr 2, 2008 | 05:43 PM
accordfreak's Avatar
do you guys have clicking issues in the front too? car is off, i let the car roll down the driveway slightly, I step on the brakes and hear the clicks.
Old Apr 2, 2008 | 07:00 PM
roodawg2's Avatar
I sounds like when a torque wrenck clicks. It only does it when i get on it or roll back and put it in 1st it does it. The guy that put it on took off the sway bar to put them on. You think something he did to the sway bar may have something to do with it. The ride did get stiffer. My car is not lowered n has 20s staggered.
Old Apr 2, 2008 | 08:45 PM
g35man04's Avatar
CLUB MODERATOR
then that means you have the axle click...I talked to my tech today when I picked up my car......he said that if you roll forward or back from reverse or 1st gear and you hear a clicking sound its the axle click that has the Technical Service Bulletin out for it...
Old Apr 2, 2008 | 10:37 PM
roodawg2's Avatar
what is that?
Old Apr 3, 2008 | 11:05 AM
roodawg2's Avatar
took the car into the dealership and its an axle click. I appreciate all of your help guys.
