Hey guys help me diagnose this :)
Old Apr 17, 2008 | 10:08 AM
lov3rboy408's Avatar
Originally Posted by 2fast
I got warranty but i have aftermarket pads and rotors plus camber kits & suspension
U know they'll say im not covered anymore because of my aftermarket parts
sorry to said this but that something you have to deal when moding your car!.. can't solve the problem go back to stock bring to the dealer have them check!
Old Apr 17, 2008 | 09:22 PM
Curt G's Avatar
Originally Posted by whtskylinegt350
yeah the way to check the abs is pump up the brakes with the car off then start the car with your foot still holding the brake the pedal should sink a little bit if the abs is working which is what they tell you in school, or you could do a burn out with traction control on my favorite way
That's how you test the brake booster (the power part of power brakes), not ABS.
Old Apr 17, 2008 | 09:24 PM
Curt G's Avatar
Yes, you're right. The dealership will not go out of its way to fix your brakes after you put on aftermarket pads and rotors (not that it's a bad thing to replace with aftermarket). But, like other people said, it probably just needs a good bleeding. Replace all your brake fluid now, since it should be changed every now and then due to water absorption.
Old Apr 17, 2008 | 09:33 PM
whtskylinegt350's Avatar
thanks for the help drankin and studying doesnt really help all that much . still got the ase for brakes tho
Old Apr 17, 2008 | 10:57 PM
Joe_Camel's Avatar
2fast - maybe you bought crappy brake pads (you mentioned you have 'aftermarket' pads)? Also the OEM pads on the 03-04 were really soft and extra brakey.
My navigation doesnt display any notifications. My 04 G35 would tell you when your fuel is low, problem with ABS,etc, This one doesnt show anything like that.. is this normal..
There's a fuel gauge and ABS warning light in the cluster in front of your face near the speedometer and tachometer.
Old Jun 13, 2008 | 03:12 PM
orl-g's Avatar
having similar issues with brembos on my 04. actually i hear a ratcheting noise coming from rear of engine on passenger side, probably the brake booster or master cylinder. also feel a click/ratcheting through the brake pedal. this is only on decceleration, only when not on gas pedal.
Cajuncowboy
Jun 21, 2021 09:47 AM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
underworld
Aug 6, 2015 01:36 PM
Frostbite91
Jul 27, 2015 05:25 AM
