how to remove this sht
how to remove this sht on the roof
this shark on the roof
[/QUOTE]
I am afraid that there can be some traces or holes ! what i need to do
thanks guys
[/QUOTE]I am afraid that there can be some traces or holes ! what i need to do
thanks guys
Originally Posted by overdrve
just rip it up or run some fishing line along the bottom. it's going to leave some adhesive so you'll have some clean up afterwards.
wd40, blow dryer, fishing line, and goo gone.... in that order...
spray wd40 let sit for 10 min... heat up with blow dryer, use fishing line.. then use goo gone to remove any leftover glue... follow by a wax
if you're still going to keep the satellite radio and want the actual shark fin, check out my DIY: https://g35driver.com/forums/audio-video-electronics-diy/194889-diy-satellite-shark-fin-install-headliner-removal.html
Originally Posted by Bigd2k6
if you're still going to keep the satellite radio and want the actual shark fin, check out my DIY: https://g35driver.com/forums/showthread.php?t=194889
^this shows the fin with wire going through the roof so there is a hole in it.
On SEGAS pictures wire is on top of the roof and goes in to the car between the rear glass and the roof.
So it's either magnetic or taped.
Originally Posted by never gone
I just took the same one off my roof last week. It's on with adhesive and magnets.
How did you get rid of that?
Did you just cut it off by the rear window or did you cut it somewhere inside and pulled it out?
what about the wire.
