Tire Question
Old May 9, 2008 | 06:25 PM
g30wh4t's Avatar
Exclamation Tire Question
Here is what I have, front 245/35/19 Pilot Sports P2 in great condition. Rear 275/30/19 pilot sport p2. My rear tires are ready for a change 2/32 . Could I put 275/35/19 pilot sports on the rear, or will it screw something up (VDC)? Can I go Wider? Like 285, 295, or 305?
Thanks
Old May 9, 2008 | 07:01 PM
g30wh4t's Avatar
Anyone?
Old May 9, 2008 | 07:14 PM
gary c's Avatar
Tire Question....?
You have questions but you didn't give us a lot of information....what size
rim and offset? These figures are critical in choosing tire size, without it
you'll never get a correct answer to your question!
Old May 9, 2008 | 07:20 PM
g30wh4t's Avatar
19" volk te37's, don't know the offset though, they were on the car when I bought them, my main question is will 35 series be ok if the front are, right now the fronts are 35 series and the rears are 30 series
Old May 9, 2008 | 07:35 PM
avs007's Avatar
Since they are both Michelins you may be ok, since the tire sizes should be uniform across the same brand.
In my case, I had 245/40-18 Pilot Sport All/Season on the front, and when I swapped out my rear 275/40-18 Pilot Sport All/SEason for the same size Bridgestone Potenza RE960AS, my VDC kept complaining whenever I took even mild curves. It kept braking the front corner, causing the rear to step out.
I had to replace the front with RE960AS to fix the problem. In my case, I think the problem was caused by the Potenzas being slightly bigger than the Pilots for the same given size. (Especially given the fronts are already 2% off from stock)
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
