Coupe Gas Tank Fill Problem
Old May 19, 2008 | 12:54 PM
Glycerine's Avatar
Like a few on here, i've had intermittent issues with not being able to fill up an empty tank. Different pumps, stations, states, sometimes it will just take 2-5 gallons then cut off. If i squeeze the handle slightly, it'll continue filling up. Sound familiar?
I've been complaining to the dealership for a while, but this last time, the tech that was working on it said his niece's coupe had the same issue. Replaced the Schrader valve and it was gone. Getting it done as soon as i empty this tank. Will update if this ends up fixing it. Hope this helps others. Be nice to put this issue to rest...
Old May 19, 2008 | 01:18 PM
grazsrootz's Avatar
i have the same problem with my jeep haha i just keep clicking the trigger
Old May 19, 2008 | 01:53 PM
RaginRaj11's Avatar
I just started having the same problem.
Old May 19, 2008 | 02:42 PM
g35panama's Avatar
where can i buy that valve_? is it the schrader valve or the shutter valve_? can it also be the filler cap.._? where can i buy all these
Old May 19, 2008 | 02:47 PM
RaginRaj11's Avatar
Dealer.
Old May 19, 2008 | 03:30 PM
G35fromPA's Avatar
You mean the shutter valve, and this is a TSB that has been out for a while. Your dealer should have known about it.
Old May 19, 2008 | 05:16 PM
g35panama's Avatar
send me the link to buy the shutter valve,, i cant find itt
Old May 19, 2008 | 09:01 PM
Meth68's Avatar
Mine was "fixed" and it got better but still isn't fixed. It's annoying and seems picky to pumps, I have a local idea of where to/not to go.
Old May 20, 2008 | 12:46 AM
TonyG35DG's Avatar
Had the same issue fixed by the dealership under warranty, one of the fuel level sensors went bad.
Old May 20, 2008 | 12:58 AM
RaginRaj11's Avatar
Will they still fix it if the car is out of warranty?
Old May 20, 2008 | 01:44 AM
Meatshackle's Avatar
Deep Sea Moderator
I just got some recall work done on the fuel filler hose.
Old May 20, 2008 | 12:15 PM
Glycerine's Avatar
Well he said Schrader valve, which as far as i know is for tires, but i know f all about the fuel system so i just shrugged and said ok
I'll ask them about the shutter valve TSB when i call em up to sked the appointment. Thanks for the heads up.
Blakearold
Aug 19, 2015 10:20 AM
newg37
Jul 26, 2015 09:32 AM
brian_z
Jul 22, 2015 09:19 PM
ZacDesu
Jul 14, 2015 11:13 PM
