Strange humm noise on 04 coupe on deceleration..
Old May 29, 2009 | 12:40 PM
G35ANSTA's Avatar
I had a humming noise coming from the rear tires for about 6 months and i was able to rule out the tires when i did my usual switch from summers to winter tires. The humming noise was still present and could be heard loudest when i reached speeds above 40mph. I could still hear the noise in neutral as I slowed down with out use of the brakes. So, I was able to rule out the tires and the brakes. This also meant it wasn't the transmission because I could still hear it in neutral.
I have extended warranty so I took it to the dealer and gave them all the info I had gathered so they could troubleshoot. It turned out the problem was worn out wheel bearings. They were replaced at no charge-problem fixed!
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
atk08
Jul 30, 2015 03:12 PM
Jussaku
Jul 29, 2015 11:45 AM
rping
Jul 26, 2015 09:53 PM
