Crap! Clutch noise...help
Old Apr 29, 2004 | 10:59 AM
XCELR8's Avatar
I drove about 150 miles on back home last night and drove through McDonalds (mmm) to get some food. When the car was sitting at idle, out of gear, clutch out I heard this noise like something was rubbing while spinning. I pushed the clutch in and it got quieter, put it in gear and it went fully away. Clutch out, not in gear, at idle the noise came back. Got my food (mmmm) and went home.. it did the same thing in my driveway..
Is this something to worry about?? Would a throwout bearing make the noise?? HELP!
2003 BLK/BLK 6-spd Injen clear corners
Old Apr 29, 2004 | 12:13 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Re: Crap! Clutch noise...help
X, did it sound like a diesel engine while idle...or as put by ProDrift, "a bag of marbles"? If so, I was told it's normal on the 6MT's.
2 G or NOT 2 G, there is no question!
Old Apr 29, 2004 | 12:37 PM
XCELR8's Avatar
Thats for the post :-) the engine always idles a bit clunky which I've heard is normal, but this sound was trans related I'm 90% sure
Old May 1, 2004 | 07:17 PM
Profile4's Avatar
on every car that i've hear that noise on, the main throwout bearing was the culprit...i've heard this noise alot more on my car, and when i press the clutch down, it goes away, which suggests the bearing, but i'm going to ask the service dept. about it when i service my car in 500 miles...
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick
Old May 1, 2004 | 09:43 PM
6mtInCharlotte's Avatar
I get the same noise on mine. It's very faint though.
Old May 1, 2004 | 10:22 PM
Chops1's Avatar
same noise here, noticed it in a Wendy's drive thru the other night.
chops's Avatar
Old May 2, 2004 | 02:55 AM
DragonGcoupe's Avatar
All you guys driving your car through driver thu. How can you force yourself to do it? I won't have that smell infected my new car smell. Nor the risk of a .... SPILL. Nor the risk of .. SCRAPING A RIM? Ahh the list goes on. Sorry I have a beater car, so I think I'm spoiled in babying my G. Maybe my G is spoiled too, in that regard.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old May 2, 2004 | 08:32 AM
mattycNJ's Avatar
It is a throw-out bearing. The funny part is that there is not a raplacement part for this. They replaced my tranny due to this noise & 3k later it's back. C5 corvettes are known for this as well, but the dealer says its normal. I will be making an appointment to bring my coupe back to the dealer to have it fixed AGAIN & again if necessary.
Old May 2, 2004 | 09:22 AM
GR8TG35's Avatar
Every manual I've ever owned that made a scraping or metal sound with the clutch out was usually the throw out bearing.....a $10.00 part that cost you about $400 to replace....(if you don't do it yourself), mainly because while the trans is out I would replace the clutch and pressure plate....that was a bunch of years back so I can imagine the cost for that would be alot greater now.
The bearing tends to wear and usually an indicator of it is the dry bearing sound thats associated with it......
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old May 2, 2004 | 12:04 PM
JOHNG35's Avatar
Mine does that also. Thats normal for our cars. They all do that.
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
