Flip Key
Old Dec 29, 2008 | 12:31 AM
  #211
ZeRo G35's Avatar
Trying to subscirbe to the thread...
From what I see...
I can get it done at Home Depot with a 38 practice key using cartridge A?
I only have 1 4 button flip key and want to make sure the cut will be good... because the Lowe's guy said he won't be responsible if he messes up...
Old Dec 30, 2008 | 10:14 AM
  #212
CaneZMD's Avatar
I'd like the price for a 4 button flip key for a Z.
Thanks.
Old Jan 4, 2009 | 08:40 PM
  #213
ZeRo G35's Avatar
Where did you guys put the chip at on the 4 button one? Not sure if there is an actual place for it. I opened it up the new flip key up but have not taken out the chip. Thanks for the help!
Old Jan 5, 2009 | 02:41 AM
  #214
whlee84's Avatar
just crazy glue the chip anywhere inside the cover, towards the end that is attached to the base of the key (closer to the ignition slot on your car).
Old Jan 5, 2009 | 03:43 PM
  #215
ZeRo G35's Avatar
That will not damage the chip in any way nor? Should I glue the cover with the chip or just the chip itself.
Sorry for the noob questions
Old Jan 5, 2009 | 04:29 PM
  #216
dev1983's Avatar
theres a slot on the inside cover for the chip, you have to kinda shove it in there.
Old Jan 9, 2009 | 09:49 PM
  #217
jonnyfin's Avatar
Been using my new flipkey from mykeyless for a few weeks now.. flawless!! The nightmare is over!!
Old Jan 10, 2009 | 01:10 AM
  #218
whlee84's Avatar
gluing the chip won't damage the chip. try using only a couple drops of super glue to secure the chip...
Old Jan 10, 2009 | 04:59 PM
  #219
herbzman's Avatar
Does anyone(to include ipearlg) have a pic of the 4 button key/fob he is selling for $32 shipped? The link posted is not good any longer. Cheapest I've seen on eBay is $44.95 + shipping.
Old Jan 11, 2009 | 10:08 AM
  #220
Heinz's Avatar
After putting the key together everything works like a charm, exept for the trunk opener, i also tryed the original remote, but the same, is there anything i have done in the car that wont allove me to open it with the remote? Is there any way of programming the remotes to work on the trunk again?
Old Jan 11, 2009 | 12:14 PM
  #221
lowrider's Avatar
There's a valet lock-out in the glove box that disengages the trunk remote release. Did you accidentally flip that switch?
Lou
Old Jan 13, 2009 | 02:03 AM
  #222
Bryan858's Avatar
Interesting, So is there a definete seller for good keys without having to take out the little chip and glueing it? I do't mind having to take the remotes apart and swaping in the buttons, I just don't want to mess with the original key.
Old Jan 13, 2009 | 07:18 AM
  #223
dev1983's Avatar
u'll have to take out the chip in order to start your car, or you can get another key from the dealer...which would cost you some $.
Old Jan 13, 2009 | 02:34 PM
  #224
ZeRo G35's Avatar
Everything worked out pretty good for me. Had to put the key together after it popped out and sprung everywhere but the key looks good. No complaints except for the size and that the lock button from my OLD key button is sticking a little too much in and makes it uneven with the surface. Overall looks good and works fine.
I actually put the whole chip in the tight spot that is located by the key and it snuggly fit without any glue.
This was the 4 button one. Good luck and thanks all who chimed it!
Old Jan 22, 2009 | 01:43 AM
  #225
carsoon's Avatar
I just got my flip key from ipearl today and put it together in like 30 minutes. He's a really great guy and the things looks and feels great! It's a little big, but I can live with that. I live in Canada, and I tried getting my key cut at Rona's and Canadian Tire but they both said they couldn't do it. So I took it to Home Depot and they cut it for me in 5 minutes. Works and looks great! I had a small issue at first with the lock button not working, but you just need to readjust and line up the buttons a bit better. Super easy!
