G35 At Vs Rx8 Manual
Old May 5, 2004 | 04:23 PM
  #31
takuyaah's Avatar
Re: G35 At Vs Rx8 Manual
oh ya...by the way...nice ride on your site...i like that tint job...looks really cool...better than alot of the dual tintness..i like them uniform =)
Old May 5, 2004 | 04:48 PM
  #32
sixone's Avatar
Rx8 has higher kick at higher RPM which would allow it to gain after a bad start...but I don't know if it would be enough to pull off a win to 1/4 or 100. I've heard many Rx-8 owners complain about the kick in the butt they get at high RPMs and then the dissapointment when the needle drops back down at the change of the gears.
OG 03.5
Old May 5, 2004 | 04:51 PM
  #33
takuyaah's Avatar
if its true..i agree..i am just saying..its potential is definitely better than 0-60 times...
Old May 5, 2004 | 05:37 PM
  #34
G2FAST's Avatar
I have $20 riding on the G35. The RX8 is slower, but it might be lighter than the G and gain a little in that department, overall G should take it!
In the Works:
2004 G35 Coupe 6mt
Ivory Pearl/Graphite
Z/G HOOTER'S MEET IN ONTARIO 5/15/04
Old May 5, 2004 | 10:11 PM
  #35
Jake717's Avatar
Dude, do a search on the web for 1/4 mile times and 0-60 times for the coupe. I would say after reviewing most of the pages, the g35 coupe 6mt runs 0-60 in 5.5 and 14.2 in the 1/4 although I've seen 1/4 mile times on the 6mt as low as 13.9 at Norwalk Race Track. The 5at is around 5.7 between 14.3's and 14.4's. Once again, it all depends on who is driving the car.
Old May 5, 2004 | 11:06 PM
  #36
takuyaah's Avatar
thanks for clearing that up...so i was right...g35 has advantage 0-60 ...and rx8 will eventually catch up...(from motor trend, auto week, and road and track) they all got 14.5 or better...so ya...i think its gonna be close...
Old May 5, 2004 | 11:09 PM
  #37
KAHBOOM's Avatar
The key work is powerband. The RX8 needs to be driven like you stole it in order to obtain the magazine numbers. Prolly took a few tries to get the best times to post. The G can attain to it's potential more consistently than the RX8, thus I'd give the advantage to the G unless the RX8 driverr can pull off one of it's perfect runs.
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old May 5, 2004 | 11:39 PM
  #38
takuyaah's Avatar
i agree...g35 has a lot more room to make error since the payoff is not as great...then again..we r talking about g35 auto..so...its not that easy to make an error =)
Old May 6, 2004 | 02:37 AM
  #39
robertc81's Avatar
The G35 will smoke the RX-8. Has anyone seen the best motoring video with the RX-8? They had the S2000, G35, RX-8, WRX, RSX, and Miata (thats all the cars I believe). The S2000 came first, G35 second, and I think the RX-8 came 4th. Also, 0-60, you can see in all the car magazines, the G35 is faster.
Old May 6, 2004 | 03:41 AM
  #40
takuyaah's Avatar
i agree..0-60 ...g35 auto will have an advantage over rx8 manual...again..
Old May 6, 2004 | 07:35 AM
  #41
KAHBOOM's Avatar
Yeah kinda hard to make an error in the auto. But not impossible if you are using certain techniques to try to max out it's potential. In MM mode you can blow a shift and off the line you can bog the engine down if you try to launch via brake torque from beyond the stall zone of the tc. If you don't break the tires lose the engine wil bog down. If you do... well now you're having some fun as long as the wheel spin in not excessive. More often than not however you can acheive satisfactory results by just flooring it.
2003.5 5AT
Premium Package
Tire/Wheel Package
Old May 6, 2004 | 11:51 AM
  #42
takuyaah's Avatar
well..i drove a MM on g35 b4...and i have a type-s...its really really hard to NOT shift at the right time..since all u have to do is look at the needles.....whoever doesn't let go and shift the gear is...not very smart?
Old May 6, 2004 | 01:46 PM
  #43
sixone's Avatar
takuyaahhh what is your deal with Auto's??? seems like every post you've made so far has been a post commenting on the inferiority of Auto.....
OG 03.5
Old May 6, 2004 | 02:03 PM
  #44
KAHBOOM's Avatar
The concept is easy but these cars rev up so quickly thus if you don't pay attention, for example if you are trying to keep aware of the position of your opponent, and watching the road, and if you don't keep the timing in your head in synch with the car you will be bouncing all over the rev limiter (same goes for an MT). No it's not that difficult but it is not impossible to blow a good run.
2003.5 5AT
Premium Package
Tire/Wheel Package
Old May 6, 2004 | 09:20 PM
  #45
takuyaah's Avatar
i don't have any problem with auto..i have 3 auto here....ok...wait...inferiority of auto? NO WAY ...get outta here...if auto is so much better than manual..faster more comfortable..why would they have manual?? i am just plainly saying that its pretty hard to blow your engine cuz u "forgot" to shift..or something..what is your problem now sixone? if u wanna race..get stick...if u want the comfort...get auto..what is it that you wanna argue about or comment about now? and no..not every post i've made so far been dissing auto AT ALL..i state the fact like i always do..it could be wrong..but its what i think...so ya....
