Wheel Bearings
Old May 3, 2004 | 06:28 PM
pga's Avatar
pga
Wheel Bearings
The dealership while servicing my car noticed my front wheel bearings are bent. I have not done anything to cause a problem. I have had it one year. They want to charge $590 to replace. Can I get the bearings myself?
Old May 3, 2004 | 07:30 PM
GR8TG35's Avatar
Re: Wheel Bearings
do you mean front rotors? if they are replacing the rotors, I still think that may be a little high..................
if your talking about front wheel bearings, a small but significant part on your front spindles.....
I would say that price is outrageous......
wheel bearing sets could be at most $30
Call around and find out how much other dealers would charge you.....sounds like a rip to me........
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old May 3, 2004 | 09:47 PM
KAHBOOM's Avatar
Re: Wheel Bearings
Wheel Bearings are inexpensive to replace but should be covered under warranty. Wheel rotors are a different story especially if you have Brembos
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old May 3, 2004 | 10:08 PM
phat911's Avatar
Re: Wheel Bearings
PGA,
First off, you cannot 'bend' bearings! The bearings can be loose, or worn out. The only way the dealer can tell if the bearings are worn is by removing them, cleaning them and then doing an inspection. This should also be covered under warranty. Have you changed out your wheels from stock to custom with major offset? I would take it to another dealer and have them checked. Any shop that does front-end work can check for end play fairly quickly. If there is any end-play, I would get the dealer to verify any wear and a quick call to Infiniti Corp should get this taken care of. If the bearings do need to be replaced, ask to see the old bearings. There should be a bearing assembly (the bearings, bearing cage and inner race) and also a seperate outer race. The outer race is pressed in to the wheel hub and you should be able to separate from the bearing assembly. When inspecting the bearings, look at the bearing serfaces for pits, rough serfaces or bluing. Bluing occurs when bearings are over-heated, caused by lack of grease or just loose. Please keep us posted on what you find!
C-YA!
PHAT911
Old May 4, 2004 | 05:00 PM
gunga's Avatar
Re: Wheel Bearings
Are you sure that you didn't hit anything? I had to have my front left wheel bearing replaced for about that same price, including the wheel alignment which was necessary after the installation. Mine was a result of hitting some debris on the highway.
gunga
Old May 4, 2004 | 10:26 PM
pga's Avatar
pga
Re: Wheel Bearings
Thanks for the advice. Is there a way to replace them without going through a dealer?
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
