What gas octane do you use?
Old Jul 24, 2013 | 11:29 PM
  #91
Knightstiq's Avatar
Wait a minute.....
$1.62 X 3.785 (liters per gallon) = $6.13 a gallon
I'll stick with 91 @ $4.19 a gallon at Shell.
Old Jul 26, 2013 | 02:01 PM
  #92
WVG35Coupe's Avatar
Just put premium in it and be done with it. You guys think way too much about things that don't matter. 91 vs 93? You won't notice the difference. A dyno may, but you wont.
Some of the comments here make me weep for humanity. Not filling up because you want to keep your car light? A whole tank is about 60 lbs, in a 4000 lb car, it won't matter. Not filling up to save money? You are going to burn the same amount of gas regardless of when you put it in. All you are doing is fooling yourself into thinking you are spending less because you a spending less per visit, but visiting more.
Old Jul 26, 2013 | 03:01 PM
  #93
BlackBeachG35's Avatar
I'm pretty sure the difference in weight makes a HUGE difference in performance. Formula One cars tend to run laps that are 3-4 seconds quicker (depending on the course) when they go with a light fuel load. And, as everyone knows, our cars run exactly like a modern Formula One car does.
Old Jul 26, 2013 | 03:29 PM
  #94
JKL1031's Avatar
No one take that troll bait!! Let it be!!
Old Jul 26, 2013 | 04:08 PM
  #95
WVG35Coupe's Avatar
It wasn't troll bait. Ricer kiddie bait maybe, but not troll bait. Unless you consider calling a spade a spade troll bait.
Old Jul 27, 2013 | 02:27 PM
  #96
driftsucky's Avatar
Sooooooooooooooooo, my 87octane is bad then?
Old Jul 29, 2013 | 01:43 PM
  #97
PJG35's Avatar
Is it bad for the car to switch between 92 and 93? There's only one station where I live that provides 93, but it's always the most expensive gas station. I found 92 yesterday for 80 cents cheaper than said gas station and had to fill up.
Old Jul 29, 2013 | 06:31 PM
  #98
thegreatkwijibo's Avatar
It's not really a big deal, as stated before the oem used 91 as the definition of "premium" so anything more isn't really making a difference. just stick with the 92 and you'll be fine.
Old Jul 29, 2013 | 11:01 PM
  #99
sjsharky4's Avatar
Shell 91 octane is all I use, however the 76 down the road has 100 octane for roughly 7$/gallon. Might need to try that sometime.
Old Jul 30, 2013 | 09:49 AM
  #100
WhosUrBuddiee's Avatar
Great idea! You will waste money for nothing!
Old Aug 1, 2013 | 12:53 AM
  #101
Stillen06coupe's Avatar
93+ only.... rutters when i have a good amount of rewards(usually ~.80 off per gallon), then shell in between.... and a little bit of Torco additive every once in a while to clean her out..... 97 octane with a full tank, around 104 with 5 gallons of fuel..... and the royal purple max clean with each oil change if i remember
Old Aug 1, 2013 | 12:55 AM
  #102
a full tank of gas is 160pounds.... 8lb/gallon.... thats over a tenth of a second at the strip
Old Aug 1, 2013 | 02:27 AM
  #103
Ghuss's Avatar
80$ Canadian to fill up the pig. only thing I hate about the car. coming for a 2010 si.
Old Aug 1, 2013 | 08:36 AM
  #104
You realize high octane actually is worse for your car right? You are wasting money for no damn reason.
Old Aug 2, 2013 | 07:18 AM
  #105
what do you mean by worse? im assuming mpg... i could care less about mpg.... as long as its unleaded, it wont hurt these engines
